knocking noise when coming off full lock on 4x4
have checked and double checked every thing the front is all polly bushed but just clonks every now and then when coming off lock and occasionly even after light steering and have changed both front bearings, track rod ends and lower arms
any ideas
cheers
any ideas
cheers
Outer CV joints are probably knackered, put the car on full lock & drive in a circle. If the noise gets louder the faster you go its the joints at fault.
na no noise like the clicking u would expect for them mate, this is more a big clonk i no people have had problems when there 4x4s r to low just wondering if this could be the problem
I drilled a 4mm hole through an M8 bolt in the lathe & screwed it into thread then drilled up from underneath then opened hole to 8mm from above then fitted bolt & repeated for other holes, gets the holes spot on centre as i didnt want any tolerance.
I won't pretend... I know nothing about 4x4 cosworths... but do they have a Universal Joint on the steering? Know mi fez did a bit of clunking on full lock when that was on its way out.
JoeyBoyden
04-01-2024 02:36 PM
