Shift locking!?
Old Nov 10, 2009 | 04:35 PM
jammerrs's Avatar
jammerrs
Default Shift locking!?
i was reading fast ford, as you do, and reading ades drift sierra project it said something about shift locking.
now im presuming that it means changing down a gear fast so that the back wheels lock up!?
am i right, and if i am how does it lock up?
Old Nov 10, 2009 | 04:38 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I'd say your guess is right
As to why it locks, probably car is traveling too fast for that gear?
Old Nov 10, 2009 | 04:39 PM
jammerrs's Avatar
jammerrs
yh like the rev limit wont let the wheels go round till the wheels slow down, just couldnt/cant get my head around it
Old Nov 10, 2009 | 04:53 PM
pee vee's Avatar
pee vee
easy to do on a moto x bike lol
smashin it down too many gears too fast, the back wheel just locks up. LOL
not quite the same though lol
Old Nov 10, 2009 | 06:12 PM
jammerrs's Avatar
jammerrs
must work on the same princaple,
just wundered what stops it spinning and not the engine reving way past the limiter
Old Nov 10, 2009 | 07:23 PM
ybturbo's Avatar
ybturbo
Shift lock can be done when you downshift but not blipping the throttle to match the speed. This locks the wheels for a moment only but it is enough to brake the traction to the rear...
Old Nov 10, 2009 | 09:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
exactly that in rwd.
say your second gear max speed is 60mph and you change from 3rd to second at 70 it will lock the rear wheels momentarily.
in a fwd car it will over rev the engine lol
Old Nov 10, 2009 | 09:18 PM
pee vee's Avatar
pee vee
and bend all, 16, rally car valves,, hey fudgey
Old Nov 10, 2009 | 09:25 PM
Ade's Avatar
Ade
Fast Ford snapper
Kind of but not quite!
Nothing actually to do with rev limit.... and if you did like your example at 70mph when 60mph was the redline in that gear you would probably end up with valves firing through your bonnet
Rev limiters don't protect against mechanical over revving after all...
I generally shift lock from 3rd to 2nd at 50mph and 4th to 3rd at 80mph....
It momentarily shocks the wheels to a much lower speed and therefore breaks traction.....
A similar effect to yanking on a hydraulic handbrake but much cooler, more difficult and cheaper
Also do it too much and standard MT75 mounts break!
Some gratuitous shift locking with my new Chizfab gearbox mounts
burnzy's Avatar
burnzy
burnzy
can't you do this without hitting the limiter though i thought it was all to do with the gearbox trying to spin the engine up quickly but locking up slightly due to the drag involved , i no you have to be hovering around the redline but just not over it, thats how it was with all my bikes i'v only had fwd cars so can't comment there but it must be same principle.
Old Nov 10, 2009 | 09:34 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ade, did you ever see our old drift shitter?
that got plenty of shift lock action at teeside, but it was very wet and slippery.
i cant actually remember the gear speeds, that was just an example i gave
Old Nov 10, 2009 | 09:37 PM
Ade's Avatar
Ade
Fast Ford snapper
Yeah, it was a properly 'orrible thing! But being a drifty Sierra still cool!
I can't get enough of mine.... back up to Crail this sunday
PS, Not knocking your speeds, just that it's not actually to do with the rev limiter
Old Nov 10, 2009 | 09:40 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i didnt say it was, i said in gear speeds.
so if you are going faster in say 3rd than 2nd can do and shift down, it will lock the wheels.
but in a fwd car it will more than likely bend valves. that was the only reference to a rev limit.
Old Nov 10, 2009 | 09:54 PM
Ade's Avatar
Ade
Fast Ford snapper
But if you're changing down at faster than what the lower gear can cope with you will by definition be over the redline.... Ideal situation is to change down into the redline.
Also FWD won't be more likely to damage anything... just that you'll loose some traction up front instead.... which is a bit pointless
Old Nov 10, 2009 | 09:59 PM
fraser9764's Avatar
fraser9764
works well in empty tranny pickups you dont even need to be anywhere near the rev limiter, just as you are turning in, drop it a gear, foot away from the throttle, and dump the clutch, then as you feel it slide slightly, smash the throttle pedal and slide into the nearest hedge
Old Nov 10, 2009 | 10:08 PM
dug112y's Avatar
dug112y
passionford pro
works extremely well when racing quads too
Old Nov 10, 2009 | 10:24 PM
Ade's Avatar
Ade
Fast Ford snapper
Alrighty? Hows it going mate? Long time no see.... You got your Fiesta up and running?
Old Nov 10, 2009 | 10:27 PM
dug112y's Avatar
dug112y
passionford pro
just started a thread on it in rebuilds/restos. been busy as hell so just getting back at it now but its cracking on quickly.
Old Nov 10, 2009 | 10:33 PM
Ade's Avatar
Ade
Fast Ford snapper
Good stuff, will have a wee look in at that
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
Billy_RS
Sep 13, 2015 04:17 PM
