auto lights
Old Nov 3, 2009 | 12:55 AM
THE RADMAN's Avatar
THE RADMAN
Default auto lights
ive got hold of a new shape fiesta with auto h/lamps,where is the sensor for these? ive been told its built into the screen but there is a dome shaped sensor on the top of the dash,is this it?
Old Nov 3, 2009 | 10:28 AM
THE RADMAN's Avatar
THE RADMAN
up
Old Nov 3, 2009 | 06:04 PM
Dome shaped bit behind mirror(look for a 5mm hole with a tiny black led type looking thing in it, this is the photocell), the sensor if fitted at lower screen is the rain sensor.
The system can be disabled though if wished.
Old Nov 3, 2009 | 06:10 PM
I think the dome shaped sensor on the dash is for your air con.
Old Nov 3, 2009 | 06:16 PM
stevedohc16v's Avatar
stevedohc16v
Look through the windscreen where the rear view mirror is mounted, you will see two clear looking LEDs these are the rain sensing elements.
Steve
Old Nov 3, 2009 | 06:34 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll also have auto wipers as well then i'd have thought
it's a light sensor behind the inside mirror and, if you were to require a new windscreen you'd have to tell them it's got auto lights as the screens are designed differently with no heater element there and the darker colours there as well
the seonsors tend to rip when they come off though so if you did need a screen make sure they remove it VERY carefully
Old Nov 3, 2009 | 06:57 PM
THE RADMAN's Avatar
THE RADMAN
ok,thanks folks
Kam B
Sep 24, 2015 10:40 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
The Enigma
Sep 12, 2015 10:12 PM
gingeRS
Sep 4, 2015 06:29 PM
