Modifying a Swedish inlet to fit....
*** Sierra RS Custard ***
Doable, but personally I would use something nearer in terms of size to begin with, like a pulsar one, the YB is a very long engine compared to a 206GTI engine.
all you need to do for a pulsar one is buy a pulsar plenum, but a throttle body manifold including the injector boss, buy some spacers, make a mounting plate (or buy one from Neil Adams on Vaxusport) make a spacer plate (or buy one from Neil) and thats it done.
Same way I did my nova inlet using an RS200 plenum.
If you wise then you can use TBs instead of spacers, and end up with a multi throttle setup.
Mine cost me about 800 all in, its a few hundred more if you decide to go multi throttle.
No point in using the cossie one. If you want to do it reasonably cheaply cut up a stock inlet manifold and use that as a base. Best thing to do is cut it just after the injector bosses. You can then build your trumpets, plenum etc onto that.
Yes mate.
Jenvey TB manifold
Jenvey TB blanks as spacers
RS200 Inlet Plenum
Aftermarket Trumpets inside plenum
Vectra V6 throttle body (same size as rs200 one)
To put it together we just knocked up an adaptor plate with a file and a drill and a saw on the bench at home, and made some gaskets the same way.
Parts cost was IIRC
Manifold + fuel rail : 300
Spacers : 200
RS200 Plenum : 125
Trumpers : 60
Vectra TB : 20
Gasket Paper : 5
So a total of around 700 quid, and Ive still got all the saleable parts if I ever want rid of it so should get most of my money back, or if I put the engine in something with less height room like a VX220, I can swap to a pulsar plenum instead very cheaply
Jenvey TB manifold
RS200 Inlet Plenum
Parts cost was IIRC
Spacers : 200
RS200 Plenum : 125
Trumpers : 60
Vectra TB : 20
Gasket Paper : 5
Yes mate.
Jenvey TB manifold=========================(Would be for 206 ew engine?)
Jenvey TB blanks as spacers==================(???????)
RS200 Inlet Plenum=========================(Swedish cossie plenum)
Aftermarket Trumpets inside plenum=============(I Understand)
Vectra V6 throttle body (same size as rs200 one)===(I Understand)
Where did the adaptor plate go? Between the head and Jenvey manifold?
Sorry about all the questions
Parts cost was IIRC
Spacers : 200
RS200 Plenum : 125
Trumpers : 60
Vectra TB : 20
Gasket Paper : 5
So a total of around 700 quid, and Ive still got all the saleable parts if I ever want rid of it so should get most of my money back, or if I put the engine in something with less height room like a VX220, I can swap to a pulsar plenum instead very cheaply![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Parts cost was IIRC
Spacers : 200
RS200 Plenum : 125
Trumpers : 60
Vectra TB : 20
Gasket Paper : 5
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
