Ford Transit clock/spanner help!!!
Old Nov 1, 2009 | 04:02 PM
Turner RS's Avatar
Turner RS
Default Ford Transit clock/spanner help!!!
Got an 04 transit and it has a digital clock in the rev counter bit, i disconnected the battery for a while, just connected it back up and the clock is all garbled? Also the spanner light which lights up to indicate service is very faintly lit its bright on the ign on bit but once running faint Anything i can do????
Old Nov 1, 2009 | 04:07 PM
DangerousBryan's Avatar
DangerousBryan
does the clock say "diag" in it. if it do's its in transport mode. don't know how you have done that though if it is.
try resetting the service light. press and hold down the throttle followed by the brake pedal,keeping them both pressed down turn the ignition on,the spanner should start to flash,then turn the ignition off.
Old Nov 1, 2009 | 04:59 PM
Turner RS's Avatar
Turner RS
It doesnt say anything its just garbled?
Old Nov 12, 2009 | 07:25 PM
andrewg's Avatar
andrewg
did you find a fix?
Old Nov 13, 2009 | 07:14 AM
As said above put your feet on the brake and throttle pedal turn ingnition on and wait for the light to flash.Then turn the ignition off.
Old Nov 13, 2009 | 08:55 AM
andrewg's Avatar
andrewg
thats spanner(service) reset
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Adam-M
Aug 27, 2015 08:55 AM
SteveyDee
Aug 25, 2015 07:48 PM
borboyous
Aug 22, 2015 11:17 AM
