cosworth engine evo running gear
seen this on a couple of cars now. Is it a straight forward match or is custom stuff need to be made?
any pics of this setup?
The Special One
I only know of the DJM KA with Cossie engine and Evo transmission off the top of my head.
I also know of a 4x4 MK6 RS2000 with I4 engine and Evo transmission and the Tadstar (?) MK3 Fiesta with full Evo engine and running gear.
There may be more, but that's all I can think of off the top of my head.
ive heard of a few cars runnin the skline running gear. and thers a KA running evo gear.
i dont think u can run the evo gear in a sapphire becuse the mounts the wrong way. but the skyline is (providing you have all the tools) relativly simple. u just need an adaptor for the bellhousing
Carbon Crazy
fergie if your thinking of doing in your FRP then speak to pumaspeed and DJM as i think someone at least started building one.
![](http://i6.photobucket.com/albums/y206/warrenpenalver/evopuma2.jpg)
![](http://i6.photobucket.com/albums/y206/warrenpenalver/evopuma1.jpg)
![](http://i6.photobucket.com/albums/y206/warrenpenalver/evopuma3.jpg)
![](http://i6.photobucket.com/albums/y206/warrenpenalver/evopuma4.jpg)
scroll to bottom of this page: hes had it online like 5 years.
http://www.pumaspeed.co.uk/feat.htm
*** Sierra RS Custard ***
That's how it read to me anyway, I dont see why you choose to read it like the guy was a total fucking retard instead!
See quote above, it's pretty clear to me what the question is? The answer is NO, and i was hardly trying to insult the guy or I would've said something more malicious.
I don't see the need to be pedantic and analyse everyones reply. Can we not have a bit of "banter" without you getting upset, is that ok with you? Thanks for your input though, i liked the technical bit.
Aye it'll all bolt straight in
So if I was asking the same question, it would be because I was aware of the amount of work to fit Evo running gear to a KA, but because I had some weird ford loyalty that made me want to use a shitty YB isntead of an Evo engine and I wanted to know how much extra cost/hassle that choice of engine would cause me over just using the evo engine in the first place.
Its something ive often considered as a project in fact but using evo or gt4 running gear on a vauxhall Xe/LET engine instead, but I decided after looking into doing so that if I ever did a 4wd project I would just use the donor car's engine instead.
cheers as chip said i was refering to the box and the block, I know there would need to be lots of fabrication work in fitting the evo running gear. just seen it and had me thinking.
any more info on the puma warren?
Yes but you can't buy a whole EVO 7 for example for 3k say, but you could buy a shonky 4x4 with a good engine for that, and sell the rest, i see what your saying if you compare part for part, but not as a whole car. Right about the 4wd stuff tho, gonna replace mine when it brakes with a bara box, if i keep it that long.
yeah but cost for cost, i would imagine a 4-5k evo 4-5 would be better?
and for a 3k shitter saph the only thing worth any money with be the engine, everything else will be throw away items more than likely
V6 Ka of Love
Fergie, IIRC a Ka with rally arches is the same track as the earlier EVOs and as the engine/gearbox are transverse it should fit with less work than an inline setup, pm Screech on FK-OC, he's briefly looked into it in the past
Carbon Crazy
fergie, pumaspeed only had a little input on it at the start.
Dont know what happened to it or if it was ever finished.
From what i do know was that DJM had to make the adaptors to bolt the engine on. Some one with a rs2000 4x4 was trying to do the same and found DJM were prohibitatively expensive in terms of supplying adaptors and also supplying info on the right ratios for rear diffs etc.
Its going to b easier to fit it in a puma than a KA as you have a bit more space. Still totally custom work throughout!! Would be far cheaper and easier to go down the longtitude YB route.
big_Rad
15-09-2017 09:36 AM
Zoggon
10-08-2015 10:39 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
