plumbers help/ boiler help please
evening;
my baxi combi boiler has 0 pressure showing on the gauge; so i think it needs topping up with water?
question is how do i do it? lots of taps on the underside but dont want to start fiddling
i dont want to do anything that gonna blow me up!
boiler in question: 105e baxi
cheers
![](http://i218.photobucket.com/albums/cc60/LHD220Turbo/DSCN1444.jpg)
![](http://i218.photobucket.com/albums/cc60/LHD220Turbo/DSCN1445.jpg)
cheers
![](http://i218.photobucket.com/albums/cc60/LHD220Turbo/DSCN1446.jpg)
at the bottom of the picture to the right is your check valve (long silver compression fitting.if you follow it down find the flexible stainless braided hose (filling loop ) which is connected to your heating return pipe. there should be a valve from the cold water pipe just turn that valve and watch the gauge .fill to 1.5 bar.
gaz
gaz
gaz
gaz
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
gaz
gaz
bang on the money all i would say is fill to 1 bar as it will rise to 1.5 bar when in use
they shouldnt really need topping up, you could have a very minor leak somewhere.
go into a plumbers merchant and ask for fernox leak sealer. get the one you can inject via the filling loop. with your system pressure at 0 inject the fernox into the system then top up boiler pressure to 1.5 bar. should cure your constant topping up. done this to my aunties system and its been good for the last year
It's a rented place, so I'll nag the landlord, he's the tightest shit I've ever met, even with me and he's been me mate for 25 years!!
Bloody door handle fell off tonight, so more expense I have to try and get out of him, thanks for the advice I heard of fernox but thought it was a cleaner stuff for the system!!
out of interest, what will it do if the boiler is used at 0 bar pressure, not sure how long it had been at zero as only pulled down the cover to look tonight - i still had hot water and the radiators were hot
only symtom i had was one of the radiators upstairs was warm'ish rather than hot
Christian and Beccy
13
06-05-2006 09:50 PM
