Shoddy workmanship
#46
remember a lad I know took his car there and did 192bhp at the wheels. He supercharged it (only low boost) and on a different set of rollers got 196bhp (I think) at the fly![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I'd take a guess at P.J Motorsport as well
#54
They are not in the West Midlands and l very strongly doubt and would be massively surprised if Mark would have done that, so l am unsure what you are trying to achive by your cryptic response other then to start an argument or piss him of,
Maybe l have missinterprated your reply if so sorry but l think it reads the way l have intepreated it...
Mike
Mike
#55
14000+ post superhero
I agree, to help with this the company is based in the west midlands.
#56
lol loving the crank sensor...
this is what we do when we are using a 36-1...
First we make an ally braket to suit... (this was on a Porsche 928)
http://www.mtechautomotive.co.uk/gui...7s_Porsche_928
![](http://www.mtechautomotive.co.uk/guides/images/thumb/TWBR1.jpg/200px-TWBR1.jpg)
Then we machine and fit a trigger wheel to the crnak pulley...
![](http://www.mtechautomotive.co.uk/guides/images/thumb/Metrotriggerwheel.jpg/200px-Metrotriggerwheel.jpg)
Thats just us though....
:P
:P
#57
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
This is purely my opinion i might add!
Ok, in the bottom left corner you have zero load (throttle position & map sensor calculated load) and zero revs (engine speed). In the top right, you are 'flat out' with full load and full revs.
So, you would expect the reference to happen in between these two red lines if you floored it from idle in gear and pulled to the rev limiter.
![](http://img.photobucket.com/albums/v208/STslayer/idiotmap1.jpg)
Now, looking at the values in this fuel table, you will see there are A LOT the same! I've highlighted in boxes the big chunks to clarify...
![](http://img.photobucket.com/albums/v208/STslayer/idiotmap2.jpg)
According to this map, the engine needs the same amount of fuel at 1200rpm as it does at 8500rpm if you look at the top line!
And - on the 2nd and 3rd lines down for the load, it requires more fuel at lower revs than it does high. Admittedly you can find that as the turbo runs out of puff at very high revs, it needs slightly less fuel, but certainly not like that.
So, if we put our expected window of reference in picture one over picture two - it looks a little like this:
![](http://img.photobucket.com/albums/v208/STslayer/idiotmap3.jpg)
It appears that once it's "in the ballpark" - that value seems to be good enough for nice big blocks!
VERY rough mapping, no compensation for the changes in volumetric efficiency the engine WILL go through during the rev range and i would imagine the fuelling is pretty far away from where it needs to be.
I would also imagine that it drives pretty rough too. If plotted in a graph, it would look something like the himalayas! It should be nice smooth flowing lines...
Hopefully that will let the 'less mapping familiar' in on things...
#62
#67
#68
All the OE items had white insulation, all the aftermarket replacements have black
