connecting a universal lamba to original loom 4x4 cos
on the 3 pic original lamba plug what wire would u put to each pin with the universal sensor
cheers
cheers
Team HOTHOT!
Just be very careful using a "universal" Lambda sensor - had issues with one on mine and the software would only work properly once I installed a genuine OEM lambda (Stu sells them for Ł70) - at all other times, it wasn't running in closed loop mode when it should of been.
na not running closed loop yet just wanted it to run a afr gauge, and it is a k plate so wanted to wire it back up as it should be
cheers
cheers
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
