opening a bonnet on a 2001 transit with no key
18-10-2009, 06:03 PM
500bhp Cosworth in making
my lock is fooked to open my bonnet on my transit as you have to put them in the grill on this model.
how can i get the bonnet open??
even partialy drilled it with no luck
18-10-2009, 06:05 PM
YES I KNOW I CANT SPELL
ive dun a focous at work with the same sort of set up as long as its cold you can pull the frount bit of the under tray off and get your arm up there i had to pull the rad down a bit as well
18-10-2009, 06:09 PM
make sure the grill is not interfering with the key, you can just pull this off if it is in the way
18-10-2009, 06:20 PM
i done mine mate ,you cant get your hand up [well i couldnt] so drilled it out then opened it with a screwdriver
cheers james
18-10-2009, 06:36 PM
which way do you turn to get it open?
18-10-2009, 06:38 PM
left to unlock (pop) then right to open
18-10-2009, 06:39 PM
right till it pops up then left to fully open it
18-10-2009, 06:40 PM
2 good answers
18-10-2009, 06:43 PM
Quote:
Originally Posted by
miller3
+1
18-10-2009, 06:49 PM
Let me go and check, but im sure im right fpmsl
18-10-2009, 06:50 PM
can you get it to pop? if so you should be able to get a ratchet spanner in there to undo the 2 bolts that hold the stricker to the bonnet.
18-10-2009, 06:58 PM
18-10-2009, 07:21 PM
C4 opens them, or a blowtorch, failing that just tell some pikeys there's some copper under the bonnet!!
19-10-2009, 07:17 AM
What type of key will open any lock........
A pi-key
19-10-2009, 08:18 AM
cant even get it to pop cheers
19-10-2009, 08:57 PM
In that case Stu you will probably have to try to unbolt the 8mm's on the latch and use some long nose pliers to twist it open! pop the grill out too mate.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
tankybaby66
06-02-2016 02:24 PM
A.t.p
23-10-2015 07:54 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
Neil Clark
21
01-10-2015 07:02 PM
2001 ,
2003 ,
bonnet ,
catch ,
focus ,
ford ,
hot ,
key ,
lock ,
mk ,
open ,
opening ,
pull ,
sale ,
transit ,
unlock
