best cosworth con rods
Old 23-12-2004, 10:14 PM
abdr500
abdr500's Avatar
Default best cosworth con rods
whats the best con rods i can put in a turbo cossy iam talking the best and prices on them
Old 24-12-2004, 12:26 AM
Rick
Rick's Avatar
Farnden H Section Steel at around 800 pounds?
Old 24-12-2004, 01:44 AM
puddy
puddy's Avatar
carillo ,american rods ,the exchange rate is fantastic!
puddy
Old 24-12-2004, 02:00 AM
Fastmaul
K155MYRS
Fastmaul's Avatar
I was thinking the same...Carillo rods, Arrow, Pauter.
Old 24-12-2004, 06:20 AM
Jim Green
Jim Green's Avatar
Carillo and Arrow....... I did spend some time looking into this a while back. Arrow in particular seem very good. But the aftermarket ones (Farndon, Carillo etc) are all very good. And as Puddy said, the exchange rate is very good. But.... it's f-cking killing me as I get paid in US Dollars......Arghhhhhh.
Good old P&O Shipping.
Old 24-12-2004, 06:45 AM
Moose 130
Moose 130's Avatar
Carrillo don't list them as application for a YB.
I've emailed them to see if they can help.
See just how cheap they will be.
Old 24-12-2004, 07:22 AM
GARETH T
GARETH T's Avatar
unless you are going for crazy crazy power this is nothing wrong with standard rods! spend the money else where
Old 24-12-2004, 07:26 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
If you are going to spend the money on rods, do NOT get standard length ones .
Old 24-12-2004, 07:30 AM
Karl
Norris Motorsport
Karl's Avatar
Mike, in theory what you say is good advice, but for the vast majority of folk would be a bad idea.
The reason its a bad idea is because firstly folk will then have to start sourcing specially made pistons with a revised pin height or pin diameter, and then the issues of ring design and crown machining become an issue as its going to be a completely custom piston. In addition most folk won't know what length the rod is supposed to be anyway, so may in fact make things worse!! LOL
My advice is keep to std rod length and std rods, unless you want more than 600bhp/8000rpm.
Old 24-12-2004, 08:01 AM
Mike Rainbird
Caraholic
As it happens, I sell the correct size rods and pistons as a kit...
These rods are the same ones as used in Per Eklund's Pike's Peak SAAB and are made from ENB 24 steel - rated to 900bhp. These particular rods are 8mm longer than standard and combined with the shorther compression height pistons (to suit a standard crank and block) will do the business. We also do a set for a stronger steel crank with a better big end bearing for high rpm (9500)....
Old 24-12-2004, 08:10 AM
Eagle
Super Moderator
PassionFord Gold Member (Male)
Super Moderator
Eagle's Avatar
and the price is ......... think of a number and add 3 zero's
the thing is ... you should have a buy 4 get one free policy .. so everyone can admire the blingness in the engine as the 5th is on display
Old 24-12-2004, 04:45 PM
abdr500
abdr500's Avatar
so how much for the kit mike
05-11-2015 08:12 PM
03-11-2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: best cosworth con rods
