fuel leak
Whassup
fuel leak
i have a leak on the fuel pressure regulator on my cosworth
what material is best to use to stop leaking this?
i have made myself a gasket, seal or pressure ring (whatever that thing calls) out of some special papermaterial but it doesn't do the job
the original seals are no longer available from FORD Belgium so what's next? maybe they are still available within the U.K. ??
any suggestion welcome.
thx in advance
thx in advance
where exactly is it leaking from? there it mounts to the rail on the O-Ring?
if so are you aware that you can buy 2 types of ) ring, ones that are petrol resistant (the right kind) and ones that aint (and fall apart witin days and piss fuel everywhere)
or have you dismantled yours and now cant get it to seal back together properly?
Whassup
it's leaking on the underside of the fuel pres regulator on the fuel return line.
the fuel pressure regulator is mounted on a metal square plate and there should be, like you said, a petrol resistant ring. that ring i have made isn't a fuel resisant one. so now i need a fuel resistant one i guess
cheeRS mate
craig, as itll still leak one the fucked 20year old O-Ring
dunno about cossies, but on my V6 i had to buy a complete top end gasket set jfrom ford just to get the poxy O ring! they wouldnt sell it seperately
Whassup
buying a whole new fuel reg just for that stupid O-ring?
i don't think so...
i will find another solution rather then buy the whole fuel reg
vroooom ptssssh, don't you worry mate, i'm NOT driving it as long as it's still leaking.
i don't think so...
