Turbo compressor wheel and balance, where's best.
Team HOTHOT!
Dave, if you are fitting a new turbine/shaft at the same time, then you don't need to balance them seperately as they are component balanced thesedays
![](https://passionford.com/forum/images/smilies/roi.gif)
the core will still need to be balanced when its built though,, most places used to charge for bearings & seals at £200 odd, call around, probably about £30-50 for the balance then the compwheel.
have you fittd new bearing as they can be hard to balance on old ones.
Team HOTHOT!
Danny at Turbospares in Blackpool - he was doing a bargain kit for £150 plus delivery which was a brand new bearing core housing, bearings, seals, all the other fiddley little bits and a brand new turbine shaft/wheel unit. Only thing you'll need to add is a compressor wheel of your spec and you have a brand new unit when using your existing compressor cover and exhaust housing
Team HOTHOT!
Not true at all, if the shaft/wheel and compressor wheel are component balanced then the core does not need to be balanced.
We used to balance components and then assemble them without balancing the core when I worked at Holset
Matt Baxter
16-09-2015 08:30 PM
155lee
14-08-2015 11:21 AM
14, balance, blackpool, comp, compressor, core, dont, ford, t3, turbo, turbocharger, turbocompressor, turbos, turbospares, unit, wheel
