600bhp
http://www.pistonheads.com/SALES/lar...ke=FORD&model=
engine out this could be for sale Ł10k
long h rods
polished crank
oil jetted/ lined block
tubulor ex manifold
t6 ecu and loom
ported head , cams
coil pack
think it was 590 on super
long h rods
polished crank
tubulor ex manifold
t6 ecu and loom
ported head , cams
coil pack
550+ LUV IT!!!!!!!!!!!!!!
The 550bhp+ 3door i have cost around 20k or more with engine build, turbo, fueling, mapping etc etc, thats not the gear box either 3k on top, then big brakes to STOP!!! 2k.
You will need a big pocket m8!!!
lol at 205 block ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
200 block, 10 studs, linered, oil pump, standard crank, oil jets, longer rods, decent pistons, cams, alot of headwork, solid lifters, decent inlet, tubular exhaust manifold and a turbo suitable,
obviously all the bits around it, ecu, loom, injectors ect ect
So RS500 205 small coreplug block no good?
Mart.
B1mbo
but when we do 600hp it will make 600 at 7500-8000 and rev to 8500 ish
so it this case solid lifters are needed, liners is because the standard bores arnt as strong as a liner, and for any engine really stronger is better.
10 studs so the head is pulled down perfectly even and tightly so in cases of high cylinder pressures the head isnt going to be going anywhere
possibly overkill, but theres no point in doing things by half, do it properly once and it will last, hopefully lol
DANISH cosworth abuser
I know of a FEW sweedish and norweigan engines with 700+ bhp WITHOUT liners, so cant se a problem there, solid lifters, yes but not needed, tubular, yes for better respons and crisp engine, but not needed, and std rods are just fine for 600 bhp.
Overkill is good, but also coasts a LOT of money.
My new engine made 620bhp 470tq on optimax at 7500 and was still keen for more,
200 block, liners,cp pistons,longer rods,oil jets,knife edge crank, head work,scs spec cams,solid lifters,scs spec 8 injector manifold 2wd exhaust manifold modified for tial waste gate, scs spec turbo P8 ecu.
mainly talking about the engines we do, others do it different,
10 studs so the head is pulled down perfectly even and tightly so in cases of high cylinder pressures the head isnt going to be going anywhere![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
possibly overkill, but theres no point in doing things by half, do it properly once and it will last, hopefully lol![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Have just spoken to Joe and no that’s not the case; please people get your facts right before setting the hares running.
Remember the guy has to make a living like the rest of us and things like this can cause irreparable damage.
Brian
Brian
