After several cossies...
#121
Just thought id add this engine has been running over 600 bhp for god knows how long and it may of been mapped in japan. It made 589bhp at the back wheels the morning it lost a piston.
#124
soz to hear that pal mine had failed because someone had put a jun oil pump in it and not extended the sump or even uprated the baffle
thats 2 just bought big power gtrs ive heard of failing in the last 2 days
im sure it will come back bigger and better.
was it running standard pistons ?
#125
Mate im pete gtr
I reckon it will cost a couple of grand in parts for better stronger spec as i will be building it myself. Oh well its just a piece of metal it will fix.
#129
trust sump extension and baffle kit. whole job is about £400 for the parts and welding.
adds 1.5 litres capacity of oil and a better baffle to help prevent oil starvation, the biggest killer of rbs so im told.
i would defo get a greedy/jun oil pump aswell if it hasnt already.
#130
#134
my parts costs as a guide pistons/rings/bearings and rebore £1000
new crank £700 - £800
sump work £400
uprated big end bolts, new head bolts,all gaskets and seals,oil etc around £500
then oil pump varys from n1 £300 up to £1000 for greedy/tomei/jun
sump work £400
#135
after seeing how bad my crank was im amazed it held 2 bar hot idle oil pressure im certain a standard pump wouldnt off. it was proper fooked mate not grindable well past it so thats proof for me how good these uprated pumps are, my turbos seem good might of been a different story with standard pump.
i remember posting on here reosonable oil pressure, no smoke and just a faint noise and that was with a fubared crank !
Simmo
28-11-2006 12:19 AM
