rs turbo helpppppp !!!!!
It Wasnt Me!
yea their is if uve loosened the injector fuel lines off the top of it, or the fuel line from filter - metering head. it sounds like ure fuel pump aint working, did u not say ure fuel relay was fubar?
arr sorry forgot to say, pump is pumping as i took of the fuel line in2 filter and primed pump and fuel pissed out but not on top of metering head. the fuel fiter is brand new so dnt fink its that, my relay is ok, it wasnt making a very good contection in the plug
It Wasnt Me!
take the filter off, get someone to crank it, push the flap down about 5 mm an if theris fuel getting through the metering head the car shuld start.
will start with no filter.
i tested mine when putting my engine in and with fuel pressure i got fuel out the banjo bolts at the top where the injector lines bolt onto is it maybe the case that the metering head aint getting anything from the multi plug, not workin somehow, get it tested, dunno how someone will tell u lol
if there is fuel before the metering unit, but non coming out, the piston is probably gued up. Take the unit off which is held on by 3 torx, and use some wd40 to clean it so it moves under gravity.
there is fuel coming of metering head, the flap does move but i have 2 push it a bit for the fuel to come out. but the car still wont start, wants to but doesnt timing? there is a spark there. wot way around do the Ht leads go on? just in case i got them on the wrong way around.
nope that hasnt worked just put a new battery in 2. there is fuel going into the engine as spark plugs are wet with fuel, and there is a spark being made. ???????
It Wasnt Me!
your prob flooding it as ure cranking it, mind dont crank it for more than 10 seconds at a time, starter will fook up. It could be the timming, but it cant be that far off, what u done to the car since it was last running?
rite got a new one for u. sometimes there is a spark and other times there isnt, i have a new rotor arm and cap, plugs and coil. but not leads, but when they do spark up the spark anit that bright. help me plz
the coil is new. i have a toad alarm maybe that is tapped in2 the system some how, that mite be stopping it somehow. its realy doin my head in now
coil on its way out? coil lead not on proper?
Originally Posted by creedysRST
ahh so looking at dizzy head on it should look like this?
2-1
3-4
2-1
3-4
If you look at the end of the dizzy (from the passenger side) then rotating anti-clockwise it should be 1 3 4 2....
Can't remember if No 1 is where you have it or if it should be where you have No 2....
Easy way to find out is set the crank and cam to TDC and pop the cap off. The one that the rotor arm is pointing to is No 1....
even tho its new? i was looking in the haynes manual at the electronic spark control II (ESC II) anything to do wiv this?
i have set the crank and cam 2 TDC. when i remove the plugs and insert them into the leads to see if they are sparking up, they do somtimes and sometimes they dnt.
You confuse me. To check the spark you have to have a plug in a lead and earth the threaded bit to the engine and then crank it over. It should spark regularly....
I meant you have to set the cam and crank to TDC to IDENTIFY which one of the connections on the dizzy cap is the one which you should connect the lead to for number one cylinder....
rite i have identifed which point on the dizzy is for lead number one. maybe thats y it doesnt spark rite then if they arnt earthed but even when they are in the engine it doesnt start.
earth strap is connected
JK12
33
26-04-2021 12:09 PM
