escort diesel help please
Old 13-09-2009, 08:54 PM
tigercub
tigercub's Avatar
Default escort diesel help please
Hi, im new to this so please excuse my poor explination, i have a 1998 1800 escort TDI it has approx 150K on the clock, its been running great but has just developed and intermitant lack of power, it will start fine, pull away from cold with no undue smoke or problems, but going up a hill it will feel just like you are taking your foot off the throttle, and if you are crusing at 60mph and put your foot down its just flat, but then it will suddenly pick up, i'm thinking turbo?? should the rod on the turbo (i think its the wastegate actuator) be moveable by hand as this one feels locked, any advice please???
many thanks
Old 13-09-2009, 10:14 PM
Dan1281
Dan1281's Avatar
does it have a throttle cable or is it fly by wire?
Old 13-09-2009, 10:16 PM
tigercub
tigercub's Avatar
Hi, its cable opperated
Thanks
Old 13-09-2009, 10:24 PM
patton16i
Back in business
patton16i's Avatar
150KS ALLOT FOR ANY MOTOR MATE DIESEL OR NOT IT MAYBE JUST NEEDS A FRESHEN UP IF ITS FLY BY WIRE THROTTLE AND THINGS DONT MAKE SENCE TO THE ECU IT WILL COME UP WITH A NOTICABLE FAULT SO YOU DO SOMTHING ABOUT IT IE SO YOU DONT WRECK THE MOTOR GET IT ON A DIAGNOSIS MACHINE.A FAULT LIKE THAT WILL FLAG UP ON AN ECU
Old 14-09-2009, 07:51 AM
mozzy
Ford for life
mozzy's Avatar
ican pretty much guarantee a diagnosis here which no codereader will pick up.... the airbox to turbo hose basically implodes after a few years, easy fix but check first incse i am wrong, pull throtle leaver on the fuel pump back and rev engine up to about 4.5k then drop then rev up again and watch the hose from the airbox to turbo, it might only do it under load so give hose a gentle squeeze if it sucks in easy with the revs then hats your problem, it was a design fault that was never properly rectified. oh and 150k is nothing on that engine if well serviced they see 300k with no major issues
Old 14-09-2009, 08:22 AM
Graceland
Team HOTHOT!
Graceland's Avatar
Also, if it is the Lucas fuel delivery system (I think it will be on yours - same year as mine) then check for air leaks around the fuel filter - common problem on these (usually the top o-ring on the main clamping bolt)
150k is nothing - mine is on that and pulls very very well still
Old 14-09-2009, 08:21 PM
cabriolet
cabriolet's Avatar
agree check air filter to turbo pipe gets oil on it then goes all squidgy sucks in on boost i got a normally aspirated escort diesel done 174 thousand and still racking them up seen 300 thousand on one
Old 14-09-2009, 09:07 PM
tigercub
tigercub's Avatar
Hi, thank you all for your great advice, i will have a good look at the weekend and see whats happening.
regards
Bruce
Dr. Ickxs
15-09-2015 10:15 PM
bassboy
10-09-2015 08:54 PM
atm
07-09-2015 05:39 PM
andrewmctiernan
Wheels and Tyres
03-09-2015 08:22 PM
Bighandsuk
02-09-2015 05:23 PM
Quick Reply: escort diesel help please
