what bhp and torque figures for a t4??? (now results & graph)
Old 13-09-2009, 07:06 AM
B13 JUS
B13 JUS's Avatar
Default what bhp and torque figures for a t4??? (now results & graph)
what sort of bhp and torque figures should i see from a t4??
the mapping is'nt finished due to a few faults so it's running 25psi at the minute.
spec is...
about 7.9-1 comp
500bhp spec head
bd14 inlet cam
stand ex cam
4x4 plenum with 10mm spacer
siemens 83lbs injectors
Old 13-09-2009, 07:34 AM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
my guess 420/430bhp......350ftlbs
Old 13-09-2009, 07:58 AM
J1mbo
B1mbo
J1mbo's Avatar
435hp and 395 lb ft is my guess if your running 25 psi that is
Old 13-09-2009, 08:00 AM
KSA-Cossie
KSA-Cossie's Avatar
what boost will you be running mate ? Id guess about 453bhp and 400 lb/ft
Old 13-09-2009, 08:02 AM
J1mbo
B1mbo
J1mbo's Avatar
Originally Posted by KSA-Cossie
what boost will you be running mate ? Id guess about 4530bhp and 400 lb/ft
thats some good power
Old 13-09-2009, 08:04 AM
KSA-Cossie
KSA-Cossie's Avatar
pmsl its a mega t4 lol
Old 13-09-2009, 08:09 AM
B13 JUS
B13 JUS's Avatar
when the mapping is finished, it should be 32-34psi i think
Old 13-09-2009, 08:12 AM
B13 JUS
B13 JUS's Avatar
yes its running 25psi at the minute.
will it be the mapping that gets torque figure's like that?
Old 13-09-2009, 08:19 AM
J1mbo
B1mbo
J1mbo's Avatar
with 32-34 psi you could see 520bhp
ill guess 470-480hp and 430 lbft
Old 13-09-2009, 08:24 AM
J1mbo
B1mbo
J1mbo's Avatar
the last t4 engine running about 26 psi on a set of greys we did made 440 bhp and 410 lbft which was good
so i wouldnt think yours would be far off with similar boost
but as above with the bigger boost ill have a guess at them figures
Old 13-09-2009, 06:36 PM
B13 JUS
B13 JUS's Avatar
well it made 448bhp which i'm very happy with
not to happy with the torque 329lbs
but i had a problem with the rad, the rad is standard and i had the fans wired the wrong way after refitting it and not checking which way they went
so the car started to warm up after the second run.
also had wheel spin. guy told me that he needed to do a few runs to get heat in the tyres but did'nt want to due to the car warming up.
will the torque be low due to the fact of the wheel spin?
i will post the graph as soon as i get it scanned onto my computer
Old 13-09-2009, 06:40 PM
J1mbo
B1mbo
J1mbo's Avatar
what boost was that with ?
im not sure about the torque being out with wheelspin ive dont know about rollers much !
good power though
dave cos4x4
dave cos4x4's Avatar
448 is not bad considering the boost.
mapped,more boost should see the big 500.
Old 13-09-2009, 06:57 PM
Danny @ Enhanced Performance
Danny @ Enhanced Performance's Avatar
the reason the tourque is down is probably because on the rollers your only getting the max tourque at max revs like say 6.5k and not were youd see it on a dyno like say 4.5k,im probably not making sense but basically its like our rollers,it only gives peak tourque at the end of the rev band and not were it peaks lower down..i think its just down to tourque loads on the rollers..look at your dyno sheet and i bet that tourque figure is over 6k??cheers danny
Old 13-09-2009, 07:00 PM
B13 JUS
B13 JUS's Avatar
good power though
spiked just over 26 for a split second then held 25psi
Nash
Cake lover!
Nash's Avatar
Who's doing the mapping?
Old 13-09-2009, 07:02 PM
B13 JUS
B13 JUS's Avatar
i'm not sure what to look at on the graphs so i'll get them posted and let you guys tell me the pro's and con's
Old 13-09-2009, 07:03 PM
B13 JUS
B13 JUS's Avatar
stu and james at msd.
they told me it was about 450bhp. so it was'nt a bad guess
Old 13-09-2009, 07:08 PM
Dingy
Dingy's Avatar
Mine made 379 @ 1 bar
Old 13-09-2009, 07:11 PM
B13 JUS
B13 JUS's Avatar
whats your torque figures?
Old 13-09-2009, 07:16 PM
danneth
TORQUE!
danneth's Avatar
awful guess imo 2 bhp out
Old 13-09-2009, 07:29 PM
Dingy
Dingy's Avatar
approx 330 @ 1 bar...
at 1.5 bar made 400lb ft and 477 bhp
KSA-Cossie
KSA-Cossie's Avatar
Nice power m8.
Old 13-09-2009, 07:43 PM
B13 JUS
B13 JUS's Avatar
mine has'nt had any top end mapping so i would see better figures whenits done with the same boost i would think.
whats your spec mate?
any idea's why the torque figures are low on mine?
Old 13-09-2009, 07:44 PM
B13 JUS
B13 JUS's Avatar
Nice power m8.
thanks mate
i'm happy with the power its just the torque thats got me stumped
Old 13-09-2009, 07:57 PM
B13 JUS
B13 JUS's Avatar
here's the graph
Old 13-09-2009, 08:22 PM
here's the graph
sorry mate dont want to sound shitty but them figures are wank unless your 4wd wich i take it your not??iv never seen a 2wd cossy loose so much power through transmission as that!!over a 100bhp,either his transmission losses are way out or his dyno needs to be recalibrated..as i said earlier your tourque fig there is at the top end of the rev scale so not your peak tourque fig,id say that was awesom tourque at 6.6k and would be around 38olb ft at 4.5k ish but them rollers are wrong!!cheers danny,ps if you take the wheel fig and asume thats correct your car is 405 bhp ish,still not bad for 25 psi
Old 13-09-2009, 08:23 PM
costina
Live long and prosper!!
costina's Avatar
Operator can't even spell cossie is it me or is this car 4x4 with nearly 100bhp trans loss ? (should have read above!!)
good power figure tho
Paul
Old 13-09-2009, 08:28 PM
DAN P
DAN P's Avatar
temps were not on your side 31 c would make more out on the road
Old 13-09-2009, 08:35 PM
J1mbo
B1mbo
J1mbo's Avatar
what turbos that with ?
Old 13-09-2009, 08:43 PM
B13 JUS
B13 JUS's Avatar
not sure about the transmisson loss, i will phone them tommorrow
Old 13-09-2009, 08:45 PM
Staffi
Staffi's Avatar
T4 i think Steve,s is Jimbo...
Old 13-09-2009, 08:51 PM
yeah 2wd cossies loose about 17-18% through the transmission,that means 450 bhp with 18% loss is a 81 bhp loss making 369 at wheels as an ex..cheers danny
Old 13-09-2009, 08:52 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
As said if your car is 2wd them figures are well out.
AFR looks very rich as well
Steve
Old 13-09-2009, 08:53 PM
B13 JUS
B13 JUS's Avatar
Steve
i think thats because the mapping is'nt finished yet
Old 13-09-2009, 08:54 PM
B13 JUS
B13 JUS's Avatar
i'll phone them tomorrow and ask what the problem is.
thanks
Old 13-09-2009, 08:55 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
As long as you are happy with the way the car performs thats all that matters
Steve
Old 13-09-2009, 09:38 PM
scoooby slayer
scoooby slayer's Avatar
when your turbo was on my car at 2.2 bar it made 408 bhp at the wheels at 7600 rpm. and my ports were virtually standard size so you should see 420 + atw when its finished mate
Old 13-09-2009, 09:44 PM
scoooby slayer
my graph to compare against mate. 2.2 bar is from 5300 rpm to limiter. 4700 to 5300 rpm is 25 psi so 5000 rpm should be same as yours mate. crank power is defo out imo my graph shows 14 % losses which would make it about 405 bhp crank.
Old 13-09-2009, 10:09 PM
that power fig is more like it apart from them power losses are to low imo..14% is less than most fwd cars...thats the problem with rolling roads the transmission losses are always different..if you take the 408 at the wheels fig then thats basicly 500 bhp,thats about right with small ports..cheers danny
Quick Reply: what bhp and torque figures for a t4??? (now results & graph)
