Heater problem???
Old Sep 10, 2009 | 06:05 PM
Paul.V's Avatar
Paul.V
Unhappy Heater problem???
Hi guys and girls, could anyone shed any info as to why i have not heat coming out of my Fiesta 1.25 zetec y reg. I have drained the system and have flushed it through and have retopped it with fresh anti-freeze. I have run the engine and the temp is normal and not over heating, but only cold air is coming through the heater. Any suggestions would be gratefully received...
Old Sep 10, 2009 | 06:15 PM
I may be wrong here, but I think your car is the one that has a water valve on the bulkhead, that are notorious for giving trouble, it may be that hot water is not actually getting to the heater to start with if this valve is duff.
It should be visible on the bulkhead somewhere with two water pipes going to/from it and a cable or wire connector from the heater control.
Old Sep 10, 2009 | 06:17 PM
saph4be's Avatar
saph4be
tabetha is right it electic valve cost about 22 quid to buy common as fuck
Old Sep 10, 2009 | 06:23 PM
Paul.V's Avatar
Paul.V
Thumbs up
Cheers guys will have a look tomorrow, is it a straight forward thing to do? I take it i will have to drain the system again?
Old Sep 11, 2009 | 05:42 PM
Paul.V's Avatar
Paul.V
Thumbs up
Thanks for your advise, changed it today and everything is back to normal, cheers guys for your help
Old Sep 12, 2009 | 12:59 PM
phew!!, I got one right this year already!!
Glad it's fixed for you, especially with winter round the corner.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
