Beam and Diff mounts (advice please).
Old Sep 9, 2009 | 11:23 AM
Ridgey's Avatar
Ridgey
Default Beam and Diff mounts (advice please).
Over the winter i'll be fitting a fully adjustable Beam and would like some advice as to the best mounts (solid, poly, standard??) to use for the Beam and Diff.
What your opinions, through experience.
Guidance on price would also be appreciated.
thanks
Old Sep 9, 2009 | 11:41 AM
KSA-Cossie's Avatar
KSA-Cossie
I've got solid beam mounts and poly diff mount and an adrenaline stage 2 beam and it's perfect m8.
Old Sep 9, 2009 | 11:49 AM
Ridgey's Avatar
Ridgey
Where did you get the mount from ? And what make are they ?
Old Sep 9, 2009 | 11:51 AM
KSA-Cossie's Avatar
KSA-Cossie
Solid ones were from richie (b9 kos) and poly one was from mike r.
Old Sep 9, 2009 | 12:11 PM
joffy's Avatar
joffy
SLOW LEARNER
agreed
Old Sep 9, 2009 | 01:39 PM
Poly diff mount with std beam mounts and GGR axle tightening kit, was the best set up I've used, having recently gone to a 22mm adjustable rear arb, all I can say is get it done asap.
Old Sep 9, 2009 | 01:58 PM
joffy's Avatar
joffy
SLOW LEARNER
whats the gen on the axle tightening kit tabetha?? what is it, how does it work and what does it cost etc,
(PS cheers for the offer of the thermostat clip on the other thread, managed to scavenge one from a mate)
Old Sep 9, 2009 | 02:31 PM
KSA-Cossie's Avatar
KSA-Cossie
As above for the info on the axle kit tabs.
Old Sep 9, 2009 | 02:51 PM
Nash's Avatar
Nash
Cake lover!
Tightening kit was used in conjunction with the standard beam mounts to reduce them flexing.
Old Sep 9, 2009 | 03:23 PM
joffy's Avatar
joffy
SLOW LEARNER
sounds good, what actually is it though?? and how does it work?? and how many pounds does it cost??
Old Sep 9, 2009 | 03:37 PM
Ridgey's Avatar
Ridgey
I guess then the solid mounts would be better than, std mounts and tightening kit.
Diff mount is £125 on R&B site, any cheaper suppliers ?
Nash. You going tonight ?
Old Sep 9, 2009 | 04:51 PM
Nash's Avatar
Nash
Cake lover!
They are like a Nylon spacer that fits between the standard mounts and the chassis, i have a kit at home thats never been used, Pollys or solids only cost a little bit more though. I have pollys in at the momment and i will be fitting my solids over the winter.
Ridgy: No mate cant make it bud.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
