electric water pumps
has anyone used tis on the engine?
was looking through demonn tweeks and see the ad, seems to do the job well!
are they worth the money? and hassle to fit?
Dave Walker has used these on the cvh and i belive there was a measureable difference in parasetic losses. Also at high rpm a distinct flow improvement. Ill see if i can find an article.
what should the flow rate be any ideas chap? the engine is out of me car at the mo so will have to have a word with the fella building it see what he thinks
cheers lads
cheers lads
Great idea really, wish id got one for my cossie really, just didnt think about it at the time of ordering my new pump.
With an electric one it can be controlled based on what the engine needs, not just vary with RPM in a way that doesnt really suit whats needed.
and you could run it just before switching off and it can be left running after the engine has stopped to cool down the turbo.
I read that article and the dude in CCC mag saw gains throughout the rev range. I'm sure he got 5bhp at the top end. If remember rightly he used a 1.4 Clio cam belt which was the right length and type. if I'd have kept my S2 I'd have done that and gladly taken the 5bhp fankyou very much!
Used a belt why ? there electric ? I just took of my water pump, used blanking plate with the right outlet on, and plumbed the EWP in and wired
it up. they are very very efeiciant, mine is on a switch so i can get it up to
temp a bit quicker aswell .
Mine is on a tvr engine in a saph and i did actually just remove the impellar
open it out slightly with a die grinder, then got the hole welded up . I did
have a blanking plate diy job but didnt use it, but all the angles and reducers come with the kit to simply plumb it into the system.
i hardly use the car so he said realibility would be a problem
basically i have no worries with what i have got so he said that for the trouble it would be to mount and stuff it would not be worth it
he has used a couple before on zetec engined motors and said that they work really well, got good results from them but reliabilty once again let them down
Gus, any chance of getting more info' as to why they failed please and was EWP asked to comment on their failure?
I don't understand why they are unreliable!
Great to hear of other peoples findings
