dificulty level ?(diff)
Old Dec 20, 2004 | 06:09 PM
righthooker's Avatar
righthooker
Default dificulty level ?(diff)
to change a diff on a 3 door how long to do for lets say a novice type person(me )any thing dodgey to look out for
Old Dec 21, 2004 | 08:35 AM
righthooker
Old Dec 21, 2004 | 08:45 AM
Bri 16v's Avatar
Bri 16v
sorry mate cant help!! never done it b4!!
Old Dec 21, 2004 | 08:50 AM
Garage19's Avatar
Garage19
The torx bolts that hold the drive shafts to the diff are a bugger!
Make sure you clean them out thouroughly, use plenty of penetrating fluid and the correct size torx bit. I usually stick something like a tyre lever under the torx bit as i am turning it to keep it square in the bolt.
Old Dec 21, 2004 | 11:08 AM
plynchy's Avatar
plynchy
Will be a lot easier if you take the rear beam off altogether. If you haven't got a lift then access is a pain in the arse. Happy spannering!
Old Dec 21, 2004 | 11:13 AM
SPADGE's Avatar
SPADGE
Its about a 2 hour job in and out but watch it doesn't fall out on your head
Old Dec 22, 2004 | 01:28 PM
righthooker
mate of mine has
will keep that in mind when my mate is under neath
Old Dec 22, 2004 | 01:36 PM
FletchCossie's Avatar
FletchCossie
Someone ask how to do a Sapphire Cossie 2wd diff and this was my reply, hope it helps:
Jack rear of the car up, undo the driveshafs (T50 hex shaped), easiest way Ive found is to undo the handbrake and take car out of gear spinning the wheels to access all the bolts, but putting handbrake back on if you have no one to hold the wheel in place while undoing them!
Once all 12 (IIRC) driveshaft bolts are undone and they are moved out the way undo the prop shaft in same way to access the 4 bolts (15mm bolts). Then undo the two top 19mm (IIRC) bolts first as these can thread when trying to get the diff back in if not lined up correctly, so take no chances!
Then support diff with a jack and undo the 4 13mm bolts holding the back plate to the chassis and remove the black bump stop thing (Slides into place on the chassis (IIRC). Then undo the centre nut and 2 front boltsand remove the 2 front ones! Then remove the long bolt (Exhaust may get in the way, depending which way the bolt is placed) and the diff should be free unless Ive missed something
It may need a bit of persuassion (Sp??) to remove it and get the rear mount over the rear ARB, but it should lower down
Old Dec 22, 2004 | 01:44 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Spadge,
You must be having LOADS of cups of tea in that 2 hours, as it should be 30-40 mins out and 30-40 mins in IF all the bolts come undone okay . Is best done with two peeps (or a jack) once you get to the point of dropping it down / putting it back, as it is awkward to man-handle in a confined space if you are doing it on axle stands.
There is also an order to do things too - undo the drive shafts FIRST or you won't be able to use the gearbox to stop the diff from rotating (and believe me, you WILL need the leverage to undo these!).
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Fezman1
Sep 7, 2015 09:34 PM
