engine splutter when foot on the throttle!!
Old Sep 3, 2009 | 08:47 PM
burnzy's Avatar
burnzy
burnzy
Default engine splutter when foot on the throttle!!
when i last took the mondy out i found that when i put my foot on the throttle as if to labour the engine a little it would cut out or splutter, then fire straight back up once off the throttle.
could this be a lamba sensor?
oh yea it's a 1.8 zetec mondy mk2 98
Old Sep 3, 2009 | 08:54 PM
wirralphil's Avatar
wirralphil
tired disconnectin the maf sensor first?
Old Sep 3, 2009 | 08:58 PM
burnzy's Avatar
burnzy
burnzy
no i haven't it's hardly on the road atm cos of the clutch being gone, i suppose i could take it round the block to check, would i need to disconnect it then see if it's still the same?
edit: i'm not used to all this modern fuel injection deffo need a lesson in the workings give me a carb and i'll strip it and set it all up no prob's give me fuel injection and i'll sit and pull things not having a clue what to do
Old Sep 3, 2009 | 09:04 PM
wirralphil's Avatar
wirralphil
just disconnect the 3 pin connection then run it round the block, if it's still the same you can rule that out.
Old Sep 3, 2009 | 09:07 PM
burnzy's Avatar
burnzy
burnzy
ok if it's not could it be the lamba noticed it does smell quite rich tbh i haven't been able to give the engine a service yet cos of cash flow but it will soon so hopefully get the list sorted.
cheers for the advice though
Old Sep 3, 2009 | 09:12 PM
fiend's Avatar
fiend
Sounds like the MAF sensor.
Old Sep 3, 2009 | 09:13 PM
turboRS's Avatar
turboRS
C16OSY
firstly check your plugs and HT leads. these suffer with tracking/ arking leads.
then check the coilpack.
Old Sep 3, 2009 | 09:14 PM
666's Avatar
666
yes that is my head
stop stalling it you big poff
Old Sep 3, 2009 | 09:25 PM
burnzy's Avatar
burnzy
burnzy
it honestly doesn't feel like leads or the like, it's specifically when i labour the engine slightly with the throttle, other than that it doesn't miss a beat and the idle is really smooth so i'd be surprised if it was but all worth a check
can't help it it's my big feet and lack of talent thats getting in the way i'm not used to a big manly car i'm used to my relliant robin, i've gone up in the world, it's got a metal body and i've even got an extra wheel now
i'v tried a choffeur (sp) to cure my lack of talent, but the misses gets angry after being tied to the seat for a day or too
atleast my car has an engine all be it with a slightly slipping clutch
Old Sep 3, 2009 | 09:28 PM
666's Avatar
666
yes that is my head
legend
Rstar_man
143
Jul 20, 2020 11:16 PM
muffster
13
Sep 3, 2015 09:40 PM
Bailes1992
Aug 16, 2015 07:14 PM
M K
Aug 12, 2015 06:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
