Question regarding long studding and 3dr head....
Old 30-08-2009 | 06:08 PM
SteveB's Avatar
SteveB
Default Question regarding long studding and 3dr head....
I have a long studded block but with a 3dr head the nuts don't fit in the holes where the head bolts go (3dr heads have smaller holes than the later Saff heads and all 4wd heads)..... Now there must be someone who's had the same problem and can tell me what they did.
CheeRS for anyomes help
SteveB
Old 30-08-2009 | 06:17 PM
cozzy jeff's Avatar
cozzy jeff
you have to get the holes machined out to accept the nuts,do a search on here im sure ive seen a thread or a photo showing this done
Old 30-08-2009 | 06:19 PM
SteveB's Avatar
SteveB
That was my guess...... bugger...
Old 30-08-2009 | 08:12 PM
cossiedave's Avatar
cossiedave
if you the arp nuts they are only 14mm socket size and not 18mm saves having the head done
Old 30-08-2009 | 08:20 PM
SteveB's Avatar
SteveB
Ahhh know what ya mean.... 14mm multi sided socket I'm guessing...
Old 30-08-2009 | 08:25 PM
cossiedave's Avatar
cossiedave
you got it m8 thats the ones
Old 30-08-2009 | 09:54 PM
SteveB's Avatar
SteveB
Right just gotta find 6 ARP nuts now.....
Old 30-08-2009 | 10:08 PM
col cos1's Avatar
col cos1
ive had to have this done twice Ł60 to have it machined,doesnt weaken the head atal
do this dont arp it,i have had arp nuts sitting garage for 4 years after a friend cracked his block useing these
Old 30-08-2009 | 11:05 PM
righthooker's Avatar
righthooker
horses for courses, by 3 door has arp uts ad i aint had a problem in 4 yars , so thr is more than one way to skin a cat as they say
Old 30-08-2009 | 11:12 PM
col cos1's Avatar
col cos1
i got given them in the boot of my car when i bought it and chose not to use them after seeing my mates block
Old 30-08-2009 | 11:48 PM
SteveB's Avatar
SteveB
I have a long studded RS500 block (properly long studded all the way to base of block) but the nuts don't fit thru the head bolt holes in the head (as it's a 3dr head)..... my plan now is get a full ARP kit and use 4 of the studs on the outer 4 and use all 10 nuts from the kit....
Old 30-08-2009 | 11:54 PM
col cos1's Avatar
col cos1
na dont mate,when i bought my car in boxes the boy had had the block long studded for 6 (mountune) stud kit and 4 arps for other 4,i phoned around at least 3-4 tuners asking about this and they all advised no for the arps as they are supposidly too hard/strong or some shit and can crack block,then i seen in 1st hand on a friends
just give machine shop your 18mm socket tell them which 6 are required and get it done it aint dear,ive had it done twice now,the grinding down of a socket is ok for the later heads not an early 3-door one
Old 02-09-2009 | 04:23 PM
SteveB's Avatar
SteveB
Heads off being machined..... hopefully have it all back in car tomorrow... Fortunatly The car/engine is at SCC so I get bto use all their stuff/ramp to get it all back together!!!!!!
Steve
jessie_rs
62
06-08-2019 10:27 PM
Music & Car Audio Chat
03-09-2017 02:24 PM
BRAMMER
15
14-09-2015 09:52 PM
andrewmctiernan
08-09-2015 04:05 PM
hopper350
04-09-2015 01:53 AM
