found me a pinto today
went to the scrap yard today on the off chance that they might have a 2.0 pinto lying around, right in the very back corner of the yard i found an old transit and what was in it, only a bloody 202 block low compression pinto, i was planning to turbo a 205 block but this is much better
so i went to the guy who owns the yard expecting an extortionate price for it and he says i can have it for 85 quid!, he says we'll drag it out, leave a deposit and come and pick it up tomorrow
top stuff, i'm a happy chappy
and its my 23rd birthday, got loads of presents AND found a cheap engine, shit hot
apparently the 202 is lower compression in the transit to produce more torque, i had one in my old capri and it was pretty torquey for what it was, does anyone know what a compression test would read on a 205 block? it would be nice to see the real difference
i think the difference is down to the position of the dizzy isnt it? apart from having harder valve seats is there a difference between a leaded and an unleaded pinto?
i'm going to do a compression test when i get it, i'm still glad i got a 2.0m pinto for 85 squd though
not really thought about it to be honest, just what i've been told by a few people, come to think about it you're right, mabey the lower compression is to be more reliable due to it being a commercial engine possibly
Gotta be for reliability mate it will probably deliver similer torque but less bhp than higher comp version, good luck with it pal
a compression test wont tell you the comp. ie 7.2.1 etc...
you need to do a volume test.
there is topics on here that can explain it better than me.
here's a quote from Chip......
"A compression test will not tell you the commpression ratio of the engine or what the intended compression ratio of the pistons is.
You will need to remove the head and measure the compression ratio to find out what you want to know."
a comp test just basically tells you the health of the pistons/rings,
hope that helps.
hope that helps.
it wouldnt tell me the CR but it would identify a difference from a 205 pinto, thats all i'm after really, to know if they actually ARE a lower compression
NO it wont...
i suggest you ask somebody who knows about engines. as you clearly dont.
a comp test basically tests the health of the piston, chamber, rings etc.
What if a 205 block has 10 000 miles on? it will probs comp test 180 per piston
what if your 202 block has 190 000 miles on? it will probs comp test 90 per piston
I hope one day i sell you an engine... i can charge a fortune and tell you its low comp, when really its an old taxi engine, with 500k on the clock!!!
have a look at this topic mate, https://passionford.com/forum/genera...ession+measure
NO it wont...
end of the day you got a 202 blocked engine for £85.
class, i would personally strip it and see whats in there and freshen up.
Good luck...
Good luck...
yeah, its worth grinding the valves in and putting some stem seals in it just for the sake of it, i'm going to have a good go at building a sealed box around the carb and using one of them fuel regs that rise with boost, if it works then great, if not i'll have to find some efi bits or adapt a different manifold or something
Adam Graham
06-09-2015 06:04 AM
