Who's got an inlet pressure tester in SouthEast? - find boostleak
Old 14-08-2009 | 04:34 PM
Jim Galbally's Avatar
Jim Galbally
Default Who's got an inlet pressure tester in SouthEast? - find boostleak
ok ive FINALLY got my car back, woot.
one minor problem tho, im ptryy sure ive got a boost leak, its fine at idle etc. its only under boost its not.
symptoms, slighly slugish/laggy acceleration and wont hold full boost higher up int he rev range.
also before this happened i had a boost hose come off and ive had to reattach it and tighten it with a screwdriver... lol
so anyway, i know that MSD use a really funky inlet pressure tester thingie where they can pressurise the intake and then easily spot leaks (last time i was up there Will found about a dozen... lol) but who else has got this facility as i dont really fancy a trip all the way up to blackpool just so they can spent 5 minutes running a simple test
experience tells me that without it it could take a long time to find the issue
Old 14-08-2009 | 05:19 PM
snoopaloopa's Avatar
snoopaloopa
I've got a test kit that just blanks the intakes and then you pressurise it and search for the leaks Got it off the bay, wasn't sure at first but it does work well enough
Old 15-08-2009 | 09:19 AM
Jim Galbally
thats exactly what im looking for, somewhere with one of those!
Old 15-08-2009 | 09:24 AM
lead_foot's Avatar
lead_foot
is awesome
You could make your own:
http://www.stealth316.com/2-pressuretester.htm
JK12
33
26-04-2021 12:09 PM
xrmalin
13-09-2015 06:52 PM
JESX12
04-09-2015 09:16 AM
CrOwSoN15
14
03-09-2015 12:21 PM
Quick Reply: Who's got an inlet pressure tester in SouthEast? - find boostleak
