closed loop(HELP)stu-james @ msd
Old Aug 10, 2009 | 04:23 PM
jason 3dr's Avatar
jason 3dr
Default closed loop(HELP)stu-james @ msd
currently running t34 .63 ,swedish,55 blacks,wasted spark, als, lc.
closed loop
just fitted stack wide band gauge ,on tickover its reading 14.7.but driving at 70mph 5th gear @3000rpm its reading as low as 11.5 ,as soon as i floor it reverts back to chip and fueling seems to be fine .dont know what to check first i've changed the narrow band but hasen't made any difference,if i drive with the narrow band unplugged fueling comes up to 13ish
any idears where to go now
also went to fordfair and mpg was about 20
Old Aug 10, 2009 | 04:33 PM
boost mad's Avatar
boost mad
The ECU needs a narrow band signal Jason. Wideband wont work
Old Aug 10, 2009 | 04:36 PM
Spiky's Avatar
Spiky
just weld anothe bung in the exhaust and run both
Old Aug 10, 2009 | 04:54 PM
jason 3dr's Avatar
jason 3dr
as per post
Old Aug 10, 2009 | 04:55 PM
jason 3dr's Avatar
jason 3dr
i am running both narrow band for closed loop,wide band for stack gauge
Old Aug 10, 2009 | 04:59 PM
jason 3dr's Avatar
jason 3dr
just had mot and co was 3 % if closed was working it should be 0.9 or below
Old Aug 10, 2009 | 05:33 PM
boost mad's Avatar
boost mad
I must of missed that part of your first post lol.
The CO should be set to around 3% ( iirc ) without the closed loop running.
What narrow band is it? do you have it wired up correctly ?
Old Aug 10, 2009 | 05:46 PM
jason 3dr's Avatar
jason 3dr
its a bosch black to pin 2 ecu ,2 white wires one live one earth
Old Aug 10, 2009 | 06:00 PM
jason 3dr's Avatar
jason 3dr
its been working for over a year ,driving along one nite put the als on for about 5 secs ,since then the fueling gone wrong
Old Aug 10, 2009 | 06:01 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Possibly the ALS has killed the narrow band sensor - have you tried a new one?
Old Aug 10, 2009 | 06:20 PM
jason 3dr's Avatar
jason 3dr
ive changed it but it made no differance .that was my first thought
Old Aug 10, 2009 | 06:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im sure i still have the sensor Stu supplied me for my closed loop.
Steve
Old Aug 10, 2009 | 08:43 PM
jason 3dr's Avatar
jason 3dr
both the two sensors i've got are from stu
Old Aug 10, 2009 | 09:31 PM
andy escos's Avatar
andy escos
bttt
Old Aug 11, 2009 | 07:22 PM
jason 3dr's Avatar
jason 3dr
tryed to set the co today at my local garage but couldn't get it below 4 % with the lamda plug in or unpluged
Old Aug 12, 2009 | 07:33 AM
That's high, mine just went through MOT at 0.97% CO, 137ppm, NOT on closed loop, and runs perfect, even idling.
Old Aug 12, 2009 | 10:07 AM
ECU Monitor Enthusiast
Assuming the car has no electrical faults and the chip software is matched to the engine spec and parts,
I reckon you have high fuel pressure .....
Old Aug 12, 2009 | 09:12 PM
jason 3dr's Avatar
jason 3dr
just checked the fuel pressure ,its 53psi with pipe off 44 with pipe on
Old Aug 12, 2009 | 09:16 PM
jason 3dr's Avatar
jason 3dr
i know the co & hc readings were hi but it was still showing afr reading of approx 14.7 and on the co machine it was lamda 1.....
any idear on what to check next
Old Aug 12, 2009 | 09:43 PM
jason 3dr's Avatar
jason 3dr
up
Old Aug 12, 2009 | 10:04 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
have you ran the IAW software on it to check for any faults? a sensor failure of some sort is probalby most likely, or an air leak
fuel pressure should be 3.5 bar at idlle with the vac pipe off,
pipe on isnt really relivant, as the figure si totally dependant on engine spec,as this effects manifold depression massively
Old Aug 12, 2009 | 11:06 PM
costina's Avatar
costina
Live long and prosper!!
James you say air leak but don't the closed loop software adjust for this???
Reason i ask is i was trying to replicate a fault on mine L8 closed loop by creating a air leak to see if idle co would rise after taking dump vac off and boost gauge pipes off and adjusted idle to suit extra air the AFR still stayed around 14 to 15
I would presume that it would rise on a L1/L6 without closed loop control
was trying to create a fault a friends car could possibly have
Paul
Old Aug 12, 2009 | 11:14 PM
JTECH James
Passion for Fords!
it will to a point, but air leaks will effect map sensor readings, which can richen things up,
and you can get air leaks on the exhaust side which make the lambda sensor read incorrectly
its totally dependant on the idle strategy as to how effective closed loop is at idle,which again relates to engine spec
Old Aug 13, 2009 | 05:46 AM
Stu @ M Developments's Avatar
PassionFords Creator
I would initially be checking the quality and accuracy of sensor inputs and the checking the quality of the lambda sensor and ECU earths on the vehicle.
This is correct. The chip has closed loop compensation settings that vary from cal to cal so where as one chip may allow a 25% compensation, another may only allow 5%. The ability to compensate also depends on the injector duty on teh load site above the correct one as the air leak will move the speed density map up a load site.
Old Aug 13, 2009 | 03:47 PM
jason 3dr's Avatar
jason 3dr
not yet will need to get it of trev secs is showing most sensors are working
Old Aug 13, 2009 | 08:54 PM
jason 3dr's Avatar
jason 3dr
james ,any suggestions on were to start from,fuel prss is correct ,ive changed the the lamba,but why is it showing 14.7 afr when the c0 is over 5%
Old Aug 13, 2009 | 08:57 PM
JTECH James
Passion for Fords!
maybe your wideband isnt caliberated correctly, or your als has damaged your wideband sensor?
Old Aug 13, 2009 | 09:12 PM
jason 3dr's Avatar
jason 3dr
even if its not reading correct i still cant get co down less than 5% and hc were over 800
Old Aug 13, 2009 | 09:18 PM
JTECH James
Passion for Fords!
would have deffo thought thats a sensor or wiring fault of some sort tbh,
chuck the iaw on it,
Old Aug 14, 2009 | 08:16 PM
jason 3dr's Avatar
jason 3dr
hopefully will get on the iaw monitor tomorrow and let you know the readings
Old Aug 21, 2009 | 08:10 PM
jason 3dr's Avatar
jason 3dr
still haven't got it on the iaw yet and still and its still pi..ing me off
Old Aug 21, 2009 | 08:12 PM
JTECH James
Passion for Fords!
bring it up for a set up
Old Aug 21, 2009 | 08:37 PM
jason 3dr's Avatar
jason 3dr
can you check a chip to see if its faulty
Old Aug 21, 2009 | 08:38 PM
jason 3dr's Avatar
jason 3dr
trying to get trev to put the iaw on it but rich has the lead and he is away
Old Aug 21, 2009 | 08:43 PM
JTECH James
Passion for Fords!
i would deffo check on the iaw first mate, id be 99% sure theres an underlying sensor issue, but yes we can test the chip, you could send it to us in your ecu, and we can test both at the same time
Old Aug 21, 2009 | 08:47 PM
jason 3dr's Avatar
jason 3dr
ideal thanks for that ........its starting to bug me now. ps hows the job going
Old Aug 21, 2009 | 09:10 PM
jason 3dr's Avatar
jason 3dr
the engine is freshly built and ive just finished running it in and just want to drive it now
Old Aug 21, 2009 | 09:23 PM
JTECH James
Passion for Fords!
going well pal,
Old Aug 25, 2009 | 08:47 PM
jason 3dr's Avatar
jason 3dr
still no joy with the iaw and donny is now 3 weeks away
Old Aug 27, 2009 | 06:41 PM
stu21t's Avatar
stu21t
any joy with this?
i had high co at idle, non closed loop
i got it on the iaw and showed the tps was incorrectly set
then found i had 2 airleaks after the throttle body even tho the engine was just built so i assumed it would be fine.
now i just gotta get it back on a co machine to check if ive fixed it.
