people using compression struts on there cossie ??
Old 10-08-2009, 02:17 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
Default people using compression struts on there cossie ??
im looking at putting comp struts on my cossie project , for the adjustability
but how do i stand regarding a front arb ?
do you use one , what setup and where from ect ,
much appriceated
beef
Old 10-08-2009, 02:27 PM
paul16v
Monte 087
paul16v's Avatar
They replace the roll bar Beefy
Old 10-08-2009, 02:30 PM
joffy
SLOW LEARNER
joffy's Avatar
i thought you could run both but the ARB runs forward of the x member, might be wrong, also have been advised not to lose the ARB if its going to be used on the road??
Old 10-08-2009, 04:14 PM
Jon(M600BHP)
Jon(M600BHP)'s Avatar
I use a bladed arb with compression struts. thx Jon
Old 10-08-2009, 04:18 PM
dojj
Resident Wrestling Legend
dojj's Avatar
if you use comp struts you will either need to run coil overs or very stiff suspension to counter the roll
or invest in a front mounted arb with drop links and stuff to counter the roll
lots of hassle but if you want it to handle then there are other cheaper more basic things you can do
my advice would be to have a short talk with rainbird to see what he suggests, although other suspension type peeps are also available
Old 10-08-2009, 04:33 PM
Jon(M600BHP)
Just looked at some pics of under my car not 100% sure it has got compression struts now?
Old 10-08-2009, 04:36 PM
Jon(M600BHP)
heres the arb
paul16v
Monte 087
paul16v's Avatar
Yeh it has Jon that is a compression strut.
Old 10-08-2009, 04:58 PM
Jon(M600BHP)
Thanks m8 i wasnt sure lol
Old 10-08-2009, 06:23 PM
-beefy-
-beefy-'s Avatar
its more for the adjustability factor , it will be running coilovers , i think ill re mock the front end in with the arb , and see whats what ,
how much are bladed arbs if i have to go that route
Old 10-08-2009, 06:59 PM
Jon(M600BHP)
Not to sure on price m8 but i think you can get bladed arbs secondhand for about 250/300 quid. thx Jon
Old 10-08-2009, 08:10 PM
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
Im sure i remember seeing some fancy kit that meant you could run a repositioned std roll bar and compression struts.
Old 10-08-2009, 09:01 PM
dojj
dojj's Avatar
yup, comp struts on the first pic
bladed front mounted arb in the second
the comp struts are easy to find and fit
the arb relocation gubins is pricey and not nearly as common as you would think
someone on here posted up pics of the official cradle gubbins for the front mount, they may be able to give you some more info on it
Old 10-08-2009, 09:05 PM
Mr C
Mr C's Avatar
You will require heavy spring poundage to make up for the removal of the ARB and to help stop some body roll so its usually only used on a track car due to the harsh ride on road. More pics of aftermarket front ARBs please, thats a good option for you
Old 10-08-2009, 09:08 PM
Psycho Warren
Carbon Crazy
is the ARB relocation kit not a cheaper and practical way of doing it for a road/occasional track day car???
Old 10-08-2009, 09:20 PM
dojj
dojj's Avatar
you can't use the standard bar mate
it's got to be that drop linked thing with the cradle and the works
Old 10-08-2009, 09:23 PM
Mike1
Mike1's Avatar
Just as an aside, I'm sure that Jay, the guy with the extremely fast white 3-door that chased Si B round at Combe in July, said he ran a front mounted ARB. His car certainly seemed to handle well
Old 10-08-2009, 09:26 PM
dojj
dojj's Avatar
if these are your pics, sorry, don'tknow who's they are so someone wil lcome and claim credit for them eventually
looks like you'll need the adjustable tca's with the correct fitments on them to take the drop links too mate
Old 11-08-2009, 04:03 AM
buzznwood
buzznwood's Avatar
The original group A blade ARB parts for the sierra never used a cross member it was basically the same components front and back, it was attached to the chassis rails using a simple bracket. This is what Jon(M600BHP) from the pics appears to be using.
You'll need to click to see the larger picture, not the best pictures but should give you an idea.
As to if you need the front ARB well as suspension and handling is one of those subjective things and down to personal preference you'll find people running with and without a ARB, now while technically an ARB is bad as it ties both sides of the suspension together with a front strut set up you just can't dial in the same amount of camber change under compression that you can with a double wishbones that typically allows you to get away without an ARB IMO.
Old 11-08-2009, 11:19 AM
wildheart
wildheart's Avatar
Im running compression struts,drop links and bladed roll bar.
Got it all from Rally Design.
Old 12-08-2009, 05:21 PM
-beefy-
-beefy-'s Avatar
this is my problem i would like the adjustability of comp struts but not the harshness thaat seems to be associated with them ,
the car will never see a track !!!!!
ill start getting the parts together and mock up the front and rear again ,
go from there ,
Old 12-08-2009, 06:08 PM
andy escos
andy escos's Avatar
Talking
the pics are from b9 cos (richie)& its just sat in his garage collecting dust the fitment has nothing to do with adjustable tca,s the bladed roll bar bolts into the end of the comp strut set up he,s supposed to be copying the whole set up as well so other peep,s can use it to so i can have a set on my car as well. hes at see for a month or so but pm him when he gets back im sure he,ll help.
Old 12-08-2009, 06:16 PM
RONNIE AMIS
RONNIE AMIS's Avatar
touring car spares do the mounts for the roll bar
http://www.touringcarspares.com/part...cat=susp#thumb
Old 12-08-2009, 06:17 PM
markk
markk's Avatar
running compression struts does not mean you have to run stupid hard springs at all.
Old 12-08-2009, 06:45 PM
Touring Car Spares
Touring Car Spares's Avatar
Thanks Ronnie ,we also fit the brackets to your car , modify your track control arms,supply bars, drop link kits , etc..etc...
Old 12-08-2009, 06:53 PM
-beefy-
-beefy-'s Avatar
how much is a set up like that tony ?
would you have to do the welding , or could you give an accurate location when supplying the kit ?
beef
Old 12-08-2009, 06:59 PM
Touring Car Spares
beef
i'd be delighted to just supply mate , welding them on is a pain unless the engines out anyway . the bar is the major expense because theyre made new from spring steel , Scotty sells Blades on e-bay , drop link kits are Ł150 the pair , bars are Ł300 ( yes, i know but its not my price ) alloy bracket sets & bushes are Ł80 ,all plus the vat + carriage . We have a 24 hour delivery on these available , other than the weld on brackets which im waiting to have re-stocked soon . The fitment to chassis is pretty self explanatory , once the blades fitted it establishes where you fit them on to keep the drop link upright .
Old 12-08-2009, 07:16 PM
-beefy-
-beefy-'s Avatar
so around 550 for the kit ?
and then id need modded adj tca's and a "blade "
is this correct fella
Old 12-08-2009, 07:28 PM
Touring Car Spares
yup , pair of blades that is , and the weld on brackets .
Old 12-08-2009, 07:38 PM
jacko
jacko's Avatar
thats actially not allot for what you get and looks like a far better way of doing it than the wrc type
Old 12-08-2009, 07:39 PM
righthooker
righthooker's Avatar
go from there ,
you have answered your own question beey , you dont need it, spend the money else where dude, you wont see a track anyhow and on the road it would just spoil it imo
Old 12-08-2009, 07:44 PM
jacko
jacko's Avatar
im with clive on this to be honest beef
it wouldnt make a nice road car
Old 12-08-2009, 07:48 PM
-beefy-
-beefy-'s Avatar
im just thinking if i need the adjustability jack .
or you reckon a set of adj tcas and some adj top mounts will be enough ,
Old 12-08-2009, 07:52 PM
righthooker
why would you need to adjust it mate , your not setting up for diferent conditions tracks ect, spend it where you need it
suspension is where your at lol
Old 12-08-2009, 08:05 PM
jacko
jacko's Avatar
tca,s and top mounts will be fine
clive his car wont drive like a cosworth and will need the adjustabuility to make it right but he wont need wrc stuff
Old 12-08-2009, 08:06 PM
-beefy-
-beefy-'s Avatar
what he said
Old 12-08-2009, 09:37 PM
andrewg
andrewg's Avatar
any coilover and comp strut with uprated spring without going stupidly stiff will give less roll than standard springs and arb,,get them on then worry about it!! then if you feel it rolls you can go that way,
Old 12-08-2009, 09:47 PM
jacko
jacko's Avatar
its going to be a bufty road car lol not realy much point in making it track set up cos it will never see the track
out of curiousity has the focus got an atb as i cant remember
Old 12-08-2009, 10:27 PM
markk
markk's Avatar
the front WRC item mounts to the front crossmember, how does this make this system beter than a WRC item ?
I ran no roll bars at all on my last car for 10 years or so
Old 12-08-2009, 10:32 PM
jacko
jacko's Avatar
far better for a road car as in an easier way of doing it aspecialy as beefys car is a mk4 escort with r wheel drive and would have no where for a wrc type to go
Quick Reply: people using compression struts on there cossie ??
