Transmission loss 4x4
Old 10-08-2009, 01:19 PM
YBJ
Thinking Cosworth..
YBJ's Avatar
Default Transmission loss 4x4
What in general is the transmission loss of a cossie 4x4 in relation to flywheel (engine) power and wheel power? Is up to 40% normal?
Old 10-08-2009, 01:40 PM
Smit
The 60ft Launch King
Smit's Avatar
Yes it is matey
Old 10-08-2009, 01:42 PM
alan12112
Focus St mk2 310 bhp :D
alan12112's Avatar
Originally Posted by Smit
Yes it is matey
that seems like alot to me smit!!
Thought it was mor like 22-25% for 4wd cars?
Or are cossies different and I don't know -
Old 10-08-2009, 02:28 PM
mechanic28
mechanic28's Avatar
on a 4x4 cossie running 400bhp i would expect to see around the 320 mark at the wheels onn a 2wd around 360 at the wheels
Old 10-08-2009, 02:59 PM
ECOS95
ECOS95's Avatar
Mine is 250BHP at the Fly & 170 @ the wheels.
Old 10-08-2009, 03:04 PM
xrsi
xrsi's Avatar
as a general rule of thumb in uni we were told toassume approx 85% efficient for FWD 75% efficient for RWD and then 50% for 4wd due to the extra diff and shafts etc.
Old 10-08-2009, 03:09 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
50%...............so ur telling me a 400bhp escos is only 200bhp @ the wheels.........c'mon think about it.....
Old 10-08-2009, 03:12 PM
Northern Bloke
Northern Bloke's Avatar
40 - 50% seemed waaaaaaaaaay high to me as I thought it was more like 25% max so did a quick search and found this article on pumaracing.com. I've read some good articles on there so I've posted an extract here and the link to the full write up is at the bottom.
The average front wheel drive road car with between 100 and 200 bhp loses about 15% of the engine bhp as transmission losses.
The average rear wheel drive road car with between 100 and 200 bhp loses about 17% of the engine bhp as transmission losses.
The 2% increase in losses over front wheel drive is because the differential has to turn the drive through 90 degrees at the back axle which soaks up a bit more of the engine's power. Copyright David Baker and Puma Race Engines
4wd cars will have higher losses because of the extra differentials and other power transmission components. The tyre and main gearbox losses will be the same though. Correlating the performance of vehicles with the both 4wd and 2wd options (Audi's and the Sierra Cosworth are examples) shows 4wd transmission losses to be about 5% higher than rwd. 22% seems to be a good average.
What each individual car loses is an unknown - it will depend on tyre sizes and pressure, suspension angles and other things, but it shouldn't be far from the figures above. For sure though, no 2wd car in the world, unless it has flat tyres and a gearbox full of sand, loses anything like 30% of the engine's power in the transmission and tyres as many rolling road operators would try to have you believe. In general though it is fair to say that low powered cars have higher % losses than high powered cars. This is because some of the frictional losses are independent of engine power and so represent a bigger drain on a small engine. For example, a 60 bhp Fiesta will have around 14 to 15 bhp total transmission and tyre loss (25%) whereas a 90 bhp XR2 will only have about 17 to 18 bhp loss (20%) - a smaller % obviously. By the time you get to RWD cars with engines in the 300 to 500+ bhp range, losses can eventually drop to as little as 12% to 14% or so.
http://www.pumaracing.co.uk/POWER3.htm
Old 10-08-2009, 03:13 PM
Jay,
Sponsor
Jay,'s Avatar
pete think about it he said uni he was either drunk or smoking a joint
Old 10-08-2009, 03:14 PM
ybturbo
ybturbo's Avatar
Mine is 330 on the wheels and 400 on the crank but in 4th where it is dynoed ... any other gear equals more lost horsepower...
pete mcrash
.......ahh school days....i can remember that far back......
Old 10-08-2009, 03:17 PM
RS 5tu
RS 5tu's Avatar
True, thats like saying a veyron is 500bhp at the wheels
Old 10-08-2009, 03:18 PM
pete mcrash
nice little read that Andy........tis good
Old 10-08-2009, 03:20 PM
Northern Bloke
Yeah, it's a good site that one Pete
As you say though 50% is maaad, that means my 4x4 is running about 100bhp at the wheels
Old 10-08-2009, 05:17 PM
Smit
Smit's Avatar
I stand corrected...Just had a look at n old rr graph... And lost about 105bhp thorugh the transmission.. (341 flywheel power)
Old 10-08-2009, 05:18 PM
YBJ
Thinking Cosworth..
YBJ's Avatar
I had done 2 rolling road sessions in the past with my cossie 4x4 and when calculating the figures, both saw about 40% transmission loss.
I also thought it was very high, that's why I ask. This friday I am doing a new session so I can compare it again.
Old 10-08-2009, 05:26 PM
dom123
dom123's Avatar
my old transmission lost 127bhp! so i bined it and went rwd!
Old 10-08-2009, 06:21 PM
pete mcrash
my last one in june......427 fly......357 atw........dastek rollers
Old 10-08-2009, 07:25 PM
dojj
Resident Wrestling Legend
dojj's Avatar
2.9 4x4 estate
177 fly = 93 atw
170 fly = 92 atw
1.8 mondeo on the rollers next to it
118 fly = 92 atw
so you figure it out because i'm stumped
Old 22-08-2009, 05:03 PM
canst
;l,kmjnhbvc
canst's Avatar
Sounds a bit over dramatic and not sure about the 4WD number, for for the others that makes sense more or less.
Old 22-08-2009, 05:17 PM
fuzzy
14000+ post superhero
fuzzy's Avatar
so a 600bhp 4wd would struggle to keep up with a stage 3 rwd?
Old 22-08-2009, 06:11 PM
Teej
Teej's Avatar
Surely it cant be that much
As a rule of thumb i thought around 21 - 26% depending on what the car is.
My EVO was 24%, but 40% loss seems crazy
Old 22-08-2009, 06:26 PM
TurboShed
Cossiemodo
TurboShed's Avatar
And your car is a 4x4 Cossy?
Old 22-08-2009, 06:30 PM
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
Who ACTUALY has compared their engine BHP on a dyno to the power in the car? IE run it in a dyno cell (TUV approved ), then on a proper set of rollers such as Dyno Dynamics?
50% or even 40% losses
The rule of thumb / fudge factor / generally accepted figure on the MLR for Evo transmission is 24%, and I bet most Cossie 4*4 trasmission losses are similar.
Most guys on the MLR now only quote the ATW (at the wheels) figure, as the bhp at the fly varies so much with the different operators and rolling roads.
At the wheels is the most important real world figure. Mine on DD rollers is 437bhp, sounds low for a GT35 running 2 bar boost, but that's all hitting the ground, unlike half the dream figures people are quoting if they are using a 50% conversion rate Does that make mine 655 bhp, cool
Old 22-08-2009, 06:36 PM
canst
;l,kmjnhbvc
canst's Avatar
I have known st220's to test at 5-10bhp more at the wheels than 330i (e46)'s.
Even though (officially) the 330 has about 5bhp more at the flywheel.
This makes me think that the losses are about 5% worse for RWD. Even so the 330 would still get from 0-60 faster thanks to grip.
Old 22-08-2009, 08:42 PM
pete mcrash
.....yup.....
Old 22-08-2009, 08:48 PM
pete mcrash
.....dont really know what u are saying/quoting....but if u read the link above (northern bloke)....it makes more sense.......the more power u have the less of a % u loose
Old 22-08-2009, 09:31 PM
xrsi
xrsi's Avatar
forgot about this thread, as i said we were told to assume that, i didnt say it was a true reflection tho did i!
i would say that it was prob 90 - 85 and 75 efficeint (fwd, rwd 4x4) to be honest as if it was that much loss through the drive train you would be seriously questioning why it would loose so much, well i would! lol
Old 22-08-2009, 10:00 PM
600bhp escos
600bhp escos's Avatar
been saying this on other threads lately..our rollers calculate 17 18% on 2wd cossys and 20 22% on 4wd...i know of two other maha rollers and every car weve done back to back have been within a couple of hp of eachother...as for si b car that would equate to 550 bhp on our rollers..cheers danny
01-11-2015 06:53 PM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
Iain Mac
30-09-2015 09:39 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: Transmission loss 4x4
