fault codes on st24
fault codes on st24
hi all,
i've been having idling problem's for a while now i changed the idle control valve and i didn't fix it. plugged in a diagnostic tool in and it come up these codes
:P1151 O2 Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1)
:P1131 HO2S 11 Indicates Lean
:P0171 System too Lean (Bank 1)
can anyone help as i haven't got a clue what these mean?
Mine used to record 1171 and occasionally 1131, I put it down to a leaking inlet manifold gasket which I could never be arsed to sort. The 'heater circuit intermittent' code sounds like a wiring or sensor fault though
Won't be your TPS daz - I reckon Spiky is on the money with the Lambda sensors. There's one on each bank pre-cat and I think another one post cat.
My ST24 didn't have a check engine light!
Si B
12-09-2015 06:49 AM
