Airtec alloy parts
Yeah very happy, tested to 450bhp they are, got recommended by a tuner, cost me £250 iirc, does its job very well, can get you discount too.
my fiesta turbo had overneating issues with a airtec radiator since i fitted it so sold it and got a pace one and never had any trouble since it certainly looked very well built tho spoke to the boy from auto specialists and he said that it was the first one he had heard of giving problems so might of been just a bad one which every company will get
i got discount on Cooler but would have got more if id of ordered rad as well, just skint at the time.
No a few lads running Airtec coolers on there motors, looks the nuts, nearly went for matt black but went for the bling look
Fleet Manager
airtec is a part of auto specialists and as with auto specialists parts are top quality and all tested with the up most though goin into fitting and minimal cutting of ur car
i have a cooler, pre rad, rad and turbo filter on my rs turbo and will be ordering the same parts for my xr when thats ready, cant fault the porducts i no the work that goes into every product so am happy to buy from them
Sapph rads and i/coolers are a good fit, although bloody heavy, very solid construction, I run both of the max sizes(width).
The only thing I would say is they could be slightly better by putting a tiny bit of a angle to the intercooler outlet pipe, then hose would fit that bit better, but still works as is.
The other annoying thing is they don't weld a fixing between the rad and i/cooler so they can be solidly bolted together, they wiggle so I just put a bit of rubber between the top edges of both where they touch and then a tie wrap around the headlight inner framework, so it's pulled nice and snug.
Would buy again without hesitation though.
sideways all the way!
i got a airtec cooler sat in me bedroom for months,not sure bout fitting as i dont want to cut my car anywhere,so does any one no if it will fit straight in place of the other? no cutting,trimming or anything?
edit to say its a 2wd saff
