BMW 3.0l x5 which side is bank one?
As title. Need to change my lambda sensor on bank one. Which side of the engine is that then?
Won't say which side is which yet but one is a caker and the other could be a twat to change. PLEASE let it be the good side
by 1st 3 which side do you mean?
is this common then? i found out while lpg guy was mapping. no fault code on dash either. then plugged in diagnostics to obd port and bank 2 is leaning off but bank 1 is ADDING fuel
and yes its my PRE cat bank 1 fucked.
from here http://www.xoutpost.com/bmw-sav-foru...-bank-1-a.html
bank 1 is drivers side. if it is you can touch the sensor so should be fine. however other side is under LOADS of stuff
"one"? there are 2 precat and 2 post cat.
Carlo if you could post a pic that would be ace. Assume you'll have a 3.0 engine car in at the mo
When you look in at drivers side you can see one sensor. Not sure if thats bank1 or 2 though.
Awright mate we dont have any in at the moment beleive it or not.
bank 1 is defo the first 3 cylinders & its before the cat so as i said before closest the the water pump front of the engine the first 3 follow the downpipe with your finger the first sensor you come to thats the one. you will see the manifolds are 3 & 3
funny thing is the light isn't on. it has been but it seems to come and go
only noticed it on plugging the diagnostic in to the port under the dash and watching the lambda readings.
Is this on LPG Chop ?
As mentioned air leak, poor mixture from LPG (if its been done)
bank one sensor 1 is the first sensor on the first 3 cylinders nearest the front panel.
If your using an OBD tool too flash code it go to parameters and select sensor one and then disconnect the sensor, if you lose the readings you obviously know you have the right sensor.
Worst scenario is a CAT fault but its more likely to be a simple lambda fault or air leak
Chop if you look in these pics there is an open 3" hose on the left hand side im sure it was that one that split on mine , its after the maf sensor so the engine runs lean.
http://cgi.ebay.co.uk/BMW-E53-X5-3-0...d=p3286.c0.m14
The petrol ecu may of re learnt on lpg after seeing a weak mixture on that bank and when on petrol its causing a EML to come on due to the fuelling being wrong.
Not uncommon, usually caused by air leaks, dirty injectors etc.. but unless you have a BMW scanner you can't zero the ecu's info to see if it only does it on one fuel.
I'd say your on the right track though with what Neil has mentioned.
Does it run the funny air bypass system across the inlet manifold ? if so are the lpg pipes before or after that or dip tubed ?
The straight 6's with air bypass have caused a few odd faults in the past
07-10-2015 12:56 PM
