Xr4x4 gearbox swap
Xr4x4 gearbox swap
Hi guys hope you can help me.i am fitting a mt75 gear box to my xr4x4 turbo.i have just broken a '92 xr4x4 2.9. I have props box starter crossmember. But i am just wondering if i need anything else before it goes to scrap.
Has anyone done this conversion? Can it be done?
If anyone wants any '92 xr4x4 bits ring me quick 07765564978.
are you swapping directly from 2.9 to 2.9 or are you doing the 2.8 fitment?
if it's the later then you need everything, including clutch, flywheel, pedal box, clutc cable, starter, complete box and front and rear props
you may also need to do some "fettling"
easier to change the pedal box to give you the correct quadrant to go with the clutch/flywheel/clutch fork assembly
you may als oneed to fit the brackets for the mount as i don't think the older cars have the sliding bits in the bottom
if you are going to use the 2.9 flywheel then a cossie clutch will fit not a problem
just make sure you get the correct release bearing for teh box though as there are 2 types
Ahhh - other side of town to me
You interested in a Magnex stainless exhaust for a 4x4 cossie - should fit the V6 downpipes with minimal fuss
Clicky Here
Clicky Here
Just spent two days struggling my tits off trying to fit this mt75 box.
Using cossie clutch,xr4x4 cover,2.9 flywheel but it will not go on.
Is there a difference in length? Are the crank bearings the same? Please help i have never struggled with either 2.8 or 2.9 like this before and ive done a few.
Well i stripped it all out checked it all fitted together put it all back and the box fell on.all fitted ok just need to put the engine back together,escort cos axle on,fit polybushes,retrim rear seat to cossie cloth etc etc etc
chowfornow
14
05-01-2019 09:01 PM
grishenko45
09-09-2015 12:58 PM
