whats ya best mod yet (cossie)?
Old 26-07-2009, 03:17 PM
  #81
dom123
dom123's Avatar
i'm not saying that a wasted spark kit is a waste of money, i'm just saying its the tiny difference!
as for jtechsaffs coment i had launch control on my saph with a dizzy and it was perfect mate!! stu did say it may not work, but sometimes it will so i was lucky.
once i posted up, why my car took a extra crank to start,and everyone replyed it was my coil pack conversion thats why i wrote that.
Old 26-07-2009, 04:45 PM
  #82
cossimc
cossimc's Avatar
Originally Posted by RWD_cossie_wil
So we are in agreement then? I was merely stating that on a 4x4 it is more vital than on a 2wd, at least 2wd brakes can handle a stage 1 just about, even standard on 4x4 brakes is on the limit IMHO!
As regards to the wasted spark, it is NOT there to sort any underlying problems, but it just removes so many weak points from the standard car!
2wd 4 pot callipers are the bollocks especially when they are brand new or reconditioned i bought a essi cos last month with stage 3 engine ect and the standard brakes were awfull they are a liabilty and look shit so i bought ap 6 pots for the front and ap 4 pots for the rear i havent tested them yet thoe as its havin a freshen up at the min but i carnt wait
Old 26-07-2009, 05:57 PM
  #83
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
Originally Posted by col cos1
i can run bigger gaps now on coilpack
....so what gaps do u run....???
Old 26-07-2009, 06:01 PM
  #84
JTECH James
Passion for Fords!
JTECH James's Avatar
i could run .75mm with the coil pack, imo you see little gain going any wider than that.
i was down to .55mm with a grp a coil at 37psi on the T4
the small plug gap had a big effect at idle, was quite lumpy
Old 26-07-2009, 06:08 PM
  #85
pete mcrash
i run .75mm on grp A coil...ngk iridium plugs....2 bar t38 and it idels perrrfect......
Old 26-07-2009, 06:27 PM
  #86
JTECH James
Passion for Fords!
do you know what you idle afr is pete?
it seems most of the guys who have said it made a big difference are on closed loop, so it may have more of an effect on the weaker running cars at idle posibly
when you look at the std systems path, from coil, through ht lead, carbon brush, rotor arm, air gap, dizzy cap, plug lead, the power has lots of chance of loosing its power on route to the plug
on a coli pack, its literally out the coil pack , down one lead to the plug, the end resuly is a much much stronger spark at the plug,
and the spark is already stronger when it leaves the pack!
there cant really be any other outcome imo
Old 26-07-2009, 06:36 PM
  #87
pete mcrash
.....no fella..........(but u knew that.....).......i know it's idel Co was 1.3ish when it was mapped 2 month ago...........
Old 26-07-2009, 06:38 PM
  #88
JTECH James
Passion for Fords!
mine was around 0.70% co at idle, so that may well be why it effected mine considerably at idle, aswell as when the cylinder pressures were high
your cr may also have an effect on full chat
Old 26-07-2009, 07:19 PM
  #89
dom123
dom123's Avatar
my old saph was on closed loop and a dizzy no problems what so ever! and my escos is closed loop with wasted spark, and they both need the same plug gap to run right 0.65mm both had 0.9co and the coil pack car takes longer to start..
i thought the idea of the wasted spark was to simply screw in some 071's and off you go, but thats not the case out comes the fella gauges!!!
Old 26-07-2009, 10:51 PM
  #90
markk
markk's Avatar
no spark plugs are 'throw in' EVER !
Old 26-07-2009, 11:10 PM
  #91
Mike1
Mike1's Avatar
Any of the big power car owners ever bother indexing their plugs?
Old 27-07-2009, 11:08 AM
  #92
Received 1,044 Likes on 998 Posts
Ive mad a few changes to my car since ive had it but they havent been performance mods.I fitted a group a coil and thats about it.I bought a set of leather seats for my car.I sould of had them in from new but when i bought it the cossie had cloth seats in it.I just try my best to keep it on the road.
boeb
09-01-2020 05:11 AM
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
Brickhouse
14
03-10-2015 07:28 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: whats ya best mod yet (cossie)?
