2wd cosworth hubs
2wd cosworth hubs
hi there iv to a set of 2wd saph cosworth hubs iv jus sand bated and cleaned up i wanted to put them on my 3dr can i put them on my 3dr will the std 3dr bottom arms fit still or will they be no gud for a 3dr
You can put the 2wd Sapphire front hubs onto a 3 door - it was done by Ford dealers occasionally when people complained about the "twitchiness" of the standard 3-door set up after the Sapphire had been launched.
Keep hold of your 3-door hubs though - they are worth a lot as lots of people with 2wd Sapphires want them to improve turn-in and raise front roll centre on their cars.
I think you will need the matching TCAs as well i.e. the Sapphire ones for Sapphire hubs
cooo lthanks for the info mate good job i found this out or eles i would off jus chucked the 3dr hubs lol so if i put ajustabe tcas on i should be ok really
ya jokein me i was jus gonna chuck em cool ill clean em up wid me sand blast box like iv done the 2wd ones and paint em black i ow ya a drink for savein me some cash
You'll easy get £100 for them, much better as is the 3 door roll bar.
But the 3 door hubs use a castle nut arrangement on the end of the tca, whereas the sapphy 2wd use a pinchbolt, so you need sapphy arms as well.
If you do want to chuck them I have a nice bin!!
If it's an early 3-door one it should have H13 on it near one of the ends of the bar
Me mates making me a new one, so I can adjust forward/rearward the wheel position/castor.
I actually have 3 door hubs and 3 door arb, but me dad nicked them for his xr4!!
The last set of 3 door hubs I bought cost me £130 delivered, but was some years ago 5+.
Ultimately the limit will be clearance at the front of the arch won't it?
The purpose of it is to be fully adjustable, someone else is setting up the actual suspension, once I have all the bits, reason I'm not after a std one is because it may be different diametre and shape to std.
hi there peeps iv got a set of 2wd hubs but the middle flange where the wheel bolts to is a bit rust and the threads are well worn i was wonderin if i could take my 3dr flanges and put em on the 2wd saph hubs would there be any differance thanks
FlashRS
13
31-08-2015 06:02 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
