group a wheel nuts/bolts
A longer bolt is a longer bolt, if indeed you actually need longer bolts.
Your car should have studs already, and yes you can get longer ones of those too, if indeed you actually need them. And stronger ones...again, if you need them.
So assuming your studs are already long enough, then you probably just need alloy wheel nuts, which any decent motor factors should be able to supply, or anywhere that sells alloy wheels.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Normal wheels studs are M12 thread, GrpA are M14 so you need them to have a built in sleeve to locate wheel correctly as the GrpA fitment wheels have bigger wheel bolt holes
davidfox280585
Shows & Track Days
17-09-2015 10:09 AM
Adam Graham
06-09-2015 06:04 AM
