engine
Old Jul 10, 2009 | 07:52 PM
1st turbo's Avatar
1st turbo
Default engine
afternoon to all, looking for a price on rebuild for me cozzy sapphire engine or is there any good 2nd hand deels going... is it harb to rebuild yourself as good around a engine change... any help greatfull cheers
Old Jul 10, 2009 | 07:55 PM
LHD220Turbo's Avatar
LHD220Turbo
if your handy with a spanner then they are one of the easiest to rebuild, Ł1500 should see you through a home rebuild inc. machining if it needs doing, cheaper if not
if you want one done for you, then let us know where about in the country you are and i'm sure we can recommend someone
Matt
Old Jul 10, 2009 | 08:04 PM
1st turbo's Avatar
1st turbo
cheers matt im in kent neer dartford bridge
Old Jul 10, 2009 | 08:08 PM
LHD220Turbo
tommy field in Essex http://www.fieldmotorsport.com/about.html
Old Jul 10, 2009 | 08:31 PM
1st turbo's Avatar
1st turbo
cheers matt will give them a bell thanks again
Old Jul 10, 2009 | 08:40 PM
LHD220Turbo
no worries; all the best with it
seriously; if you've rebuilt engines before then these YB are pretty simple things, its basically a pinto with a turbo.
my only advise if you are going to do it yourself, get the machining done by a decent machine shop (if it needs doing), take your time, dont lose patience, and keep it all clean.
Old Jul 10, 2009 | 08:49 PM
m_nettleship's Avatar
m_nettleship
Engineerin firm needs to be a good un,
Old Jul 10, 2009 | 08:52 PM
1st turbo's Avatar
1st turbo
were do i find torque settings, some people say a standard build engine is good 4 about 350hp, or is this toilet talk.. my engine is running fine at mo a bit tappy at cold start.. was looking 4 a 3 door or engine rebuild,,, belive ts a hard choice matt..
Old Jul 10, 2009 | 08:57 PM
LHD220Turbo
standard internals will handle circa 500hp, but your head will be restricted at around 420hp
if you've got a 2wd engine then they tend to be a bit tappy due to piston slap - if it aint broke dont fix it!
all torque setting are in online manuals which i'll dig out if you want
Old Jul 10, 2009 | 09:07 PM
LHD220Turbo
here you go http://www.siipicossu.com/manuaaleja...p%20Manual.pdf it takes a while to download as it 29mb, this is the one you'll need
but this one is also very handy
http://www.siipicossu.com/manuaaleja/manuaalit.htm
Old Jul 10, 2009 | 09:12 PM
1st turbo's Avatar
1st turbo
standard 2wd engine.. cheers 4 ya time very greatfull matt.. will get them down loaded thanks again. steve
Old Jul 10, 2009 | 09:20 PM
LHD220Turbo
no worries steve; if you do attempt it; there's lots of helpful people on here and you get answers really quick
Old Jul 10, 2009 | 09:37 PM
1st turbo's Avatar
1st turbo
cheers matt, no doubt i shall be asking some mad questions about rebuild,,thanks again steve
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
