grey injectors ??????
Old 13-12-2004, 08:33 PM
jakki
jakki's Avatar
Default grey injectors ??????
has anyone heard of grey injectors be modified by bosch 2 run a better spray pattern????
ive been on ebay enquiring about a set of greys that a bloke reckons has been altered by bosch....he says they came off his m8 from prisam motorsport and that they r only 2 weeks old.......he says they go for £400 a set plus fitting kit but ive never heard of it b4.....
spoof or truthful?
cheers
Old 13-12-2004, 08:43 PM
brad
brad's Avatar
iirc
there is a different fitting kit that some tuners use which contains new caps etc etc but i havmt heard of modifying the spray pattern . not sure if i,d pay £400 for 2nd hand injectors tho
Old 13-12-2004, 08:44 PM
EscortWRC
EscortWRC's Avatar
Pintle injectors CAN be re-ground to a different shape to give a better spray pattern.
Greys/403's ARE pintle type injectors, so it stands to reason that it COULD be done, but I"ve never actually SEEN it done.
Old 13-12-2004, 08:56 PM
leesrs240
leesrs240's Avatar
Seems a lot of money for greys jakki
Old 13-12-2004, 09:02 PM
Gaaables
Gaaables's Avatar
i got mine from bosh (sp) man off here along with a uprated pump including delivery and all brand new and still didnt cost £400 lol, very quick delivery as well
Old 13-12-2004, 09:32 PM
TIFF
Chasing Radders
TIFF's Avatar
I got my Fitting kit off Stu at MSD, pukka fitting kit may i add
Old 13-12-2004, 09:42 PM
Ish
Ish's Avatar
Default Re: grey injectors ??????
spoof or truthful?
cheers
they are not weber x038's are they? similar flow to a grey but better spray pattern...so i've been told!
Old 13-12-2004, 10:04 PM
abdr500
abdr500's Avatar
at burton powere in ilford they sell grays for £95 each and 30 for a fitting kit and youve still got vat so yae will cost you £400 for new one not to mention that youve still need them modifeyed if you want the better spray pattern type i should now as iam the seller on ebay
Old 13-12-2004, 10:09 PM
ImaRacing 700
ImaRacing 700's Avatar
You have 3 choices with my grey injector:-
1......Run with a cap and blow the engine
2......Run with a cap and drill them out
3......Take cap off completely to get a better spray pattern.
Your money..take the choice...all 3 cost the same unless you WANT to pay more for the better spray pattern
Old 13-12-2004, 10:12 PM
GT2
GT2's Avatar
What do you charge for Bosch 1600cc injectors Phil?
Old 13-12-2004, 10:13 PM
Alvyn
Alvyn's Avatar
Old 13-12-2004, 10:21 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Yes, it can be done.
Simple question seems necessary next....
Q) Why do you want to do this Jakki?
Greys are only around £270 brand spanking new from me and many many other suppliers... add £30 ish for fitting kit and your away...
Old 13-12-2004, 10:53 PM
Matt
Matt's Avatar
never heard of that one jakki, no caps on mine
Old 13-12-2004, 11:07 PM
marco polo
marco polo's Avatar
hello jakki
I have some X0 39 that will do the Job brand new ..these have a better spray pattern that the Grey they also atomise the feul better they are rated @ 510cc can be used on any cossie ecu
thanks marco
Old 13-12-2004, 11:11 PM
Administrator
The thing is though, theres fok all wrong with the spray pattern on a grey
Have you ever looked at one in an injector bench? Its fine, not the best, but good enough for a shonky old Pinto.. bad mappers blaming the injectors for their poor chips have given 403's a bad name and sprouted daft stories IMHO
Old 13-12-2004, 11:20 PM
marco polo
marco polo's Avatar
stu
you are 100% right but in the early days most mappers couldn't controll the grey and thats why ford went back to using the Xo38 because it was casing premiture wear on the boares of the blocks
the only reason why ford went for the grey over the xo38 in the first place was the cost as the xo38 were about £200 each injector at the time and the grey was about £50 each it was a standard injector that was fitted to the porches 911 turbo
Marco
Old 13-12-2004, 11:22 PM
Matt
Matt's Avatar
out of general curiosity whats the flow rate of xo38's vs 403's? (assuming same fuel pressure and rising ratio)?
Old 13-12-2004, 11:44 PM
marco polo
marco polo's Avatar
matt
the flow rate of the xo38 is about 10cc less ......but the xo 39 are a few cc's more
Old 14-12-2004, 02:43 PM
wimwerf
wimwerf's Avatar
can the xo39 be used with the L8 computer
Old 14-12-2004, 03:03 PM
john
john's Avatar
I have some X0 39
I have them also
Old 14-12-2004, 04:54 PM
Administrator
Yes, no problems.
Old 14-12-2004, 05:03 PM
ECU Monitor Enthusiast
This is SOOOOOO true
Old 14-12-2004, 05:54 PM
wimwerf
wimwerf's Avatar
Yes, no problems.
but are these injector that expensive......
and what about the 750cc you sell Stu( spray pattern and cost).
Old 14-12-2004, 08:36 PM
jakki
jakki's Avatar
oohh its been busy on ere..lol no he doesnt want 400 quid for them...thats what he said they go for brand new but he wants £200 for them..
what flow patteren have they been modiefied 2 run then ABDR500?
Old 14-12-2004, 09:02 PM
Administrator
Want to risk your entire engine to save £100? Really?
Old 14-12-2004, 09:05 PM
Ginge !
just finding my feet
Ginge !'s Avatar
greys second hand are worth 150 tbh , as if ya hunt about ya can find some deals, the thing ya gonna be missing is trhe fitting kit
Old 14-12-2004, 09:12 PM
Rs Gus
impreza wrx sti version 8
Rs Gus's Avatar
why bother just get std greys and let stu or a propper mapper map IT eng of
POPEYE
FAIRY CAKE
POPEYE's Avatar
personally i would only EVER buy new injectors or ones that I KNOW have been cleaned and flow tested
Old 14-12-2004, 09:15 PM
ImaRacing 700
TBH...and i may loose sales Injectors rarely fail...unlike pumps/wiring!
Old 14-12-2004, 09:17 PM
Administrator
And youve replaced how many exactly? roflol
They dont fail, that would be cool as fook but they clog up and lose their spray pattern.. then.. pop A small 10% loss of flow ona grey is 50 fookin cc remember
And yes, i do have a flow bench so yes this is real world TESTED info, so keep those adverts running Phil
Old 14-12-2004, 09:25 PM
ImaRacing 700
I have NEVER had a warranty injector and i have sold a few in 2 years...pumps,i have had 3 and 5 bar map sensors 2........
An injector has a large life before cleaning needed...and yes our company have all the Bosch jetronic items...if the filter is changed at the proper intervals then no worries.
POPEYE
FAIRY CAKE
POPEYE's Avatar
so up yours
Old 14-12-2004, 09:27 PM
Administrator
Who would ever send one back cos it was dirty FFS
Mind you....
Good time to ask whilst i remember also, do you sell the injector filter baskets?
Old 14-12-2004, 09:38 PM
ImaRacing 700
....nope not as yet...cause never been asked!..If its a real item give me a part number ...I may be Jesus but i aint God ROFL
Old 14-12-2004, 09:47 PM
Administrator
Il E-Mail ya tomorrow.
It should come as part of an injector kit which is new seals and filter basket.
Old 14-12-2004, 09:51 PM
the strut brace
the strut brace's Avatar
Originally Posted by Rs Gus
why bother just get std greys and let Stu or a propper mapper map IT eng of
gus , that could be misinterpretated, '' let stu 'or a proper mapper' map it,
you saying stu cant map there he'll have your giblets for earings
AND BEFORE ANYONE SAYS OWT , ITS A JOKE
Old 14-12-2004, 09:54 PM
ImaRacing 700
GT2 Bosch do no injectors bigger than greys...except for the air/gas which aint fuel injectors!
PS if Bosch modified any injector it would have a different part number...its total bollocks IMO.
Administrator
Bless him
Rs Gus
Rs Gus's Avatar
gus , that could be misinterpretated, '' let Stu 'or a proper mapper' map it,
you saying Stu cant map there he'll have your giblets for earings
carl i know he can roflol
Old 14-12-2004, 09:59 PM
GT2
GT2's Avatar
So this injector is not for fuel?? 0280150846
Quick Reply: grey injectors ??????
