help needed urgently!
Old Dec 13, 2004 | 10:11 AM
Gaaables's Avatar
Gaaables
Default help needed urgently!
im trying to fit my coilover kit to my escort cosworth, but ive undone the damper and got that out of the way but cant get the spring out. any1 got any tips please? c
Old Dec 13, 2004 | 10:31 AM
Gaaables's Avatar
Gaaables
sorry im on about the rear at the mo, do i have 2 remove the drive shaft?
Old Dec 13, 2004 | 10:33 AM
darren.cudd's Avatar
darren.cudd
jack the car up and stand on the wheels hub?
Old Dec 13, 2004 | 10:34 AM
Phil's Avatar
Phil
Jeebus
If it is a standard spring you may need to use spring clams to compress it enough to remove. Most shorter lowered ones can be freed using a crowbar to lever the wishbone down.
Old Dec 13, 2004 | 10:38 AM
Gaaables's Avatar
Gaaables
it is a standard spring. tryed levering it as much as i can and still no joy.
cheers for the comments guys, il keep trying the way i am then
Old Dec 13, 2004 | 10:50 AM
Fozy's Avatar
Fozy
Spring compressor is the only way to get the standards out without undoing the rear brake lines. Thats what stop it being levered down any further.
Old Dec 13, 2004 | 11:12 AM
Gadget's Avatar
Gadget
Spanner monkey
unclip the brake line out of the retainer on the body, undo the big bolt that goes through the doughnut at the front and get a big bar to push the arms down!
on the passenger side, undo the brake t piece from the body also as the brake line into it is very short and prone to snapping
Old Dec 13, 2004 | 11:15 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
if they are standard and got newys, get the angle grinder out
Old Dec 13, 2004 | 11:17 AM
heeman10's Avatar
heeman10
Grind through a spring that's so stiff he can't lever it out? Ummm BANG! Surely??
Old Dec 13, 2004 | 11:20 AM
Phil's Avatar
Phil
Jeebus
It won't be stiff but the bump stop arrangement on the body makes it hard to get long springs out.
Old Dec 13, 2004 | 11:34 AM
Gaaables's Avatar
Gaaables
cheers chaps. as said above its not the tension of the spring, its the length and way its all arranged
Old Dec 13, 2004 | 11:35 AM
heeman10's Avatar
heeman10
Ahh I seeeee. Don't want you to go ripping your brake lines out
Old Dec 13, 2004 | 11:36 AM
xr_craig's Avatar
xr_craig
Agreed if theres little tension on it.
Old Dec 13, 2004 | 11:40 AM
Gaaables's Avatar
Gaaables
did cross my mind but i ent got a grinder so best i can do is a saw. and knowing my luck id cut through the brake line
Old Dec 13, 2004 | 11:54 AM
Graceland's Avatar
Graceland
Team HOTHOT!
you'll be there forever with a saw go buy a cheepo 10 quid grinder and a pack of 5 quid disks and you'll soon have the spring in bits - cut it in 3 to get it out, nice n easy
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
