GT3076r???
GT3076r???
I've been offered a brand new one of these for £900. Its internally gated. Are these a good turbo? Whats the rough boost threashold and what engine spec do i need to make the most of it?
I think this is what cossierich has and its what i was looking at as it'll do 450 ish hp with similar response to a t34 but with a stronger top end. £900 is a good price
B1mbo
lol, there must be hundreds of threads where i argue this point
if you compare it to a ball bearing t4 then there is barely any difference, infact the t4 is probably a touch better due to the back pressure when at 510-520hp ! there isnt a massive difference though
also, being in a few gt30 powered cars recently i dont think theyre any better in the car, get full boost a tad before 4000 and pull just as well as bbt4,
just my opinion though
DANISH cosworth abuser
Jimbo : depends on the exhaust housing m8, have been in a few cars now with theese fitted, some bad, some pretty good.
It´s a big turbo, but not as bad as you make it tho.
You have to spec the turbo acordingly to the rest of the engine, not just put it on a std car and expect to get a lightning machine.
Have just tested a car with a 3076 with a 63 back housing, and was surprised to see full boost @ 3400rpm.
Car did 477bhp btw
Btw, did a comparison to s std t4, not an uprated one
Car did 477bhp btw
B1mbo
Car did 477bhp btw
Car did 477bhp btw
do you think we would would put a gt30 on a standard engine ?! lmao
all have been on a .63 housing, you saw full boost at 3400 ?!
where did it peak power ?
the ones ive been in have been road engines both 500hp at just over 7000 iirc
a really nice road engine though, for my age im old school lol, ill be going non bb t4 and rs500 inlet in my car, just like back in the 80's when 500hp was mental
Car did 477bhp btw
Car did 477bhp btw
B1mbo
and if they were 1400 thats a price from a turbo place not a private sale like paul rs is getting
a new gt30 is around 1000-1100 now with the dollar not being so good arnt they ?
well anyway there is a couple of hundred £ tops between them
i would still go for the t4,,, ever measure back pressure on a gt30 at 500hp ? even better, ever measure an internally gated gt30 at 500hp ? its scary some of the reading showed, well over boost pressure
the t4 is still quite high, dont think its quite as high though
also you have to run a dump valve with the gt30 dont have to with t4
As I understand it the ball bearing T4 has a machined shaft to convert it, and as such whilst you gain in terms of a lower boost threshold, you lose some of advantage a T4 gives - it's hard as a bare knuckle gypsy fighter. Having said that one reason to opt for a GT turbo (at least whilt the £ was strong vs the $) was that when the turbo expired it was cheaper than the T series so would just be replace. Speak to whichever tuner you go for, as they each seem to have their preferences.
All the above is IMO - I'm no expert.
the chra is the the centre housing rotating assembly
basically the core with turbines attached and balanced ready to just fit in your existing hot and cold sides
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Got you, couldn't work out if it was an acronym or a spelling mistake .. The other thing is when people compare T4 to the GT series is the majority of GT's need an external gate, so costs are very similar anyway.
But, has anyone done a back to back test on the same engine of the different turbos?
R4N SS
11
22-02-2014 07:48 PM
M K
17
21-09-2012 08:43 AM
kaking1982
12
06-08-2011 06:41 PM
Christian and Beccy
23
27-06-2008 07:28 PM
simhopper
27-02-2007 12:03 PM
