1.8 zvh pistons
1.8 zvh pistons
which pistons do i need to get,are calibra turbo pistons ok,what compression ratio would it be with standard zetec pistons with the cvh head as ive just read that the compression ratio will be very similar to a standard rst cvh engine
Mine's a 1.8ZVH. Got the standard pistons skimmed by Area 6. Can't remember the compression ratio!
Got a uprated fuel pump, beige injectors & an MSD setup, peaks at 17psi. That's pushing it tho apparently.
Looked at getting some forged pistons but were expensive from what I remember
ive got a custom inlet manifold to go on plus some beige injectors aswell just got to get a 195chip but until then im just going to run it on my 165 chip and standard injectors
I ran mine with the 195 chip but was advised to get the Evolution chip from MSD as the 195 was for a 1600 engine & a T2 turbo & I obvioulsy had an extra 200cc & a T3 turbo....I'm guessing you could be the same??
deathrider666
28-09-2015 06:12 PM
