Headlight Help
Old Jun 25, 2009 | 08:14 AM
daviddunlop83's Avatar
daviddunlop83
Default Headlight Help
Just wondering if there is a common fault with the headlights on my 3 door before i book it into auto spark
Was driving along and the dipped beam just stopped working . Side lights and ful beam are working fine tho. Ive checked the fuses and they are fine.
Thanks
Old Jun 25, 2009 | 08:35 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's either going to be the switch or even possibly an earth fault
there have also been reports that the rear lights can cause the headlights to pack up, the most obvious one being that you put the wrong bulb in the brake lights and evern time you press the brakes the headlights come on, so peole think youare flashing them through
but the switch would be the first port of call, although where you've get a replacement from is anyones guess
Old Jun 25, 2009 | 08:38 AM
daviddunlop83
Thanks i will maybe see if a friend will lend me his to try. Is it easy to test the switch without having another one? With a volt meter or anything?
Old Jun 25, 2009 | 10:29 AM
jon@work's Avatar
jon@work
There are 3 relays in the fuse box to do with the dip beam. There are 2 small ones in positions F and B, and a larger one in position II.
Is it both drivers side and passenger side that don't work (the lights are earthed differently, so this will probably eliminate relay II as being a problem)?
Are the bulbs OK ?
Have you got 12V at the headlights on the yellow wires ?
If you haven't got 12V, check for 12V at both fuses 3 and 4.
If you haven't got 12V at fuses 3 and 4, remove relay F and check you've got two 12V feeds (at one of the big terminals (30) and one of the small terminals (86)).
Old Jun 25, 2009 | 10:37 AM
daviddunlop83
Are the bulbs OK ?
Cheers i will give that a try.
Yeah it is both drivers and passenger sides.
I had a really quick look and i dont think there is any power to the head light fuses but it was a very quick look so i would need to check again for def.
Does the suggest that it is the smaller relays could be the problem?
Old Jun 25, 2009 | 10:49 AM
jon@work's Avatar
jon@work
If you've got both 12V feeds (one switched via the ignition at pin 86, and one from the stalk at pin 30), then this would suggest the relay, but if one of those feeds is missing, then it could be the stalk or the wiring to or from the stalk - you'll have to get your meter out and let us know what you've got.
Old Jun 25, 2009 | 10:51 AM
daviddunlop83
Ok that will really help me out. The car is at the painters at the min and will be back next week but im on holiday but i will let you know how i get on in a week or so.
Thanks again
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Kam B
Sep 24, 2015 10:40 AM
