Attn all loom builders, couple of bits wanted.
I'm after a couple of bits I can't get hold of,
Does any1 sell them or know where I can get them?
The plastic plug that goes into the zetec coilpack, oval plug with 3 pins,
Ford diagnostic plug, 5 pin holes but with only 3 used Inc. 3 female round pins
Sheilded cable for the map sensor, 3core cable with an earth braid PVC wrapped, 2m long
Sheilded cable for knock sensor, 2 core with earth braid PVC wrapped 2m long.
Clear heat shrink.
Cheers peeps
Clear heat shrink.
Cheers peeps
Clear heat shrink.
Cheers peeps
Clear heat shrink.
Cheers peeps
never seen the diagnostics plug so you would need to post a picture
i have also never seen the map being wired with sreen cable ,its usually crank and cam . for the map take 3 single cables a twist the 3 together this causes the cable to become shielded but not screened .
as for the twisted screen pair i have lots of cable
and how much heat shrink and what size
cheers paul
kosienutter
31
22-08-2015 09:55 AM
