will this work together
Old Jun 6, 2009 | 04:32 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
Default will this work together
im buying a 2liter dohc will my 1.6 prop and diff be able to handle it
and will it take the t9 box ??
Old Jun 7, 2009 | 07:13 PM
johnandhissaffy
bump
some please help
Old Jun 7, 2009 | 07:16 PM
dojj's Avatar
dojj
Resident Wrestling Legend
from what i can remember, the box you are currently using will fit the dohc engine
but if you are buying an engine and box, it won't fit the prop from the t9 (mt75 is bolted, t9 is sliding)
the diff will be happy though,
Old Jun 7, 2009 | 07:23 PM
johnandhissaffy
i was hoping you would answer coz you have experience with these engines i have almost have all the wiring out but its a auto box on the dohc will it fit my prop and will all the breaks need uprating
plus i will be getting a (manuel) quick steering rack
is there anythink iv missed
Old Jun 7, 2009 | 08:31 PM
johnandhissaffy
will i need the fuel rails from the tank or will it be the same
Old Jun 7, 2009 | 10:08 PM
dojj's Avatar
dojj
you need the injection tank and lines as there is a return on them
but you may have lucked out with the auto as the start is on the "wrong2 side of the engine
you may be able to get a bellhousing for the t9 to match, but you need to be either very lucky with the starter or get matching, don't forget that you need one that will not only fit the slot, but also have enough of a throw to engage and have the right teeth to mesh properly on the flywheel as you NEED to keep the dohc flywheel as it's got offset bolts and some of them aren't blind
Old Jun 7, 2009 | 10:09 PM
dojj's Avatar
dojj
also, as far as brakes are concerned, all the 90-92 spec dohc cars came with discs all round, so use these and keep the dohc master clyinder/servo arrangement as this is significantly larger and will flow enough fluid and keep the right pedal pressures to go any size of caliper you want to go on the fronts and rears
Old Jun 7, 2009 | 11:06 PM
johnandhissaffy
thanks for your help mate cheers
Old Jun 8, 2009 | 08:15 AM
Could keep the auto, put on shift kit, really makes it totally different to std auto's in behaviour, as do that to all mine.
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
