Prepare to be amazed................... Video footage
This puppy will scare the living....... out of you.
Wouldnt want to get in the way put it like that
http://amd.co.at/video/ms_36barrel.mpg
It fires 180 rounds at 1 million rounds a minute
I want one.........
I want one.........
that is fookin scary, just worked it out and with 36 barrels it has to shoot 5 from each barrel to fire 180 rounds and the fooker sounds like one gun shot seriously quick
id fookin love to know how the mechanics work on that thing for it to fire out 180 caps and it sound like one bloody shot !
piss funny
wheres my boss come here mr walker pmsl
matt
piss funny
matt
What a pile of crap, a mini-gun will out fire that thing by an order of magnitude - it also won't sound like a party popper going off. Pathetic
At first I thought it was 180rounds per min....Then - Hold on a sec......a million round a min is 16,667 per sec. With 36 barrells thats 463 per second per barrell - Not possible.
but check out the way the gun works....
So reading it apart from the actual step of electronicly starting the gun firing there is NO mechanics involved in the firing action. Nothing to jam, so it can fire 180 rounds at a RATE of 1,000,000rpm
Metal Storm's technology achieves its unparalleled performance through the concept of numerous bullets stacked in a barrel, with each bullet separated by a propellant load, such that the leading propellant can be reliably ignited to fire the bullet, without the resulting high pressure and temperature causing unplanned blowby ignition of the trailing propellant load, and without collapse of the projectile column in the barrel.
This unique concept has been accomplished through the invention of a bullet which on the one hand expands and locks in the barrel in response to high pressure immediately in front of the bullet. As a consequence, each bullet in turn can be fired in sequence from the barrel, and an individual barrel tube, loaded with numerous rounds and exclusive of any ammunition feed or ejection system, breech opening, or any mechanical operation whatsoever, when provided with an electric priming system is, in effect, a complete weapon.
Barrels can be grouped in any configuration required for a particular application, while remaining simple and compact, and have no moving parts, no separate magazine, no ammunition feed or ejection system. Excluding consideration of appropriate ancillary systems such as recoil control systems, target acquisition systems and turreting systems, the only moving parts in Metal Storm's barrel technology are the bullets.
The Youth.
30-09-2015 09:59 PM
