Rear diffs.... info and opinions pls!
Old 03-06-2009, 03:25 PM
Porkie
Porkie's Avatar
Default Rear diffs.... info and opinions pls!
I'm pretty clueless about these! I did read the feature in the Ford mag this week... but wanted to ask people opinions who have actually used them on track.
Whats the best diff for my Westy for track use? Sean has advised me I want an ATB and not a plated diff...
he said this
ATB’s are super strong!!! I have never ever heard of one braking. Plated diffs are too harsh for circuit cars IMO, as you never really want the thing to totally lock up. Plus plated diffs have a tendency to make the car push on in corners, where as an ATB is the best of both worlds, going into a corner it acts like an open diff (which is what you want for cornering) then as you power out of the corner the diff diverts the torque to the wheel that isn’t spinning, therefore putting all of your torque exactly where you want it.
They don’t have planet or sun gears Stu, so you won’t ever brake one of those, they are made up of a load of worm gears that are basically forced against each other, rather than away from each other like with conventional gears.
Just wanted to get another opinion before ordering!
Car is a Cossy powered Westfield. Fast road and mainly track use. maybe some 1/4's at some point.
Old 03-06-2009, 03:32 PM
Mr Whippy
Oderint dum metuant
Mr Whippy's Avatar
No real input to give lee, but a pic of the diff in question
Im a little bored you see....
Old 03-06-2009, 03:39 PM
B16CVH
B16CVH's Avatar
Recieved my ATB yesterday and should be fitted in the diff as we speak, mines going in a westy to! The guy doing the work for me has said he has never had a problem with any of the Quaiffe ATB`s
Old 03-06-2009, 03:41 PM
Blakeya
Blakeya's Avatar
Quaife ATB all the way mate. Had one in my westy with No problems at all. True Fit & forget item IMHO.
Andy
Old 03-06-2009, 03:44 PM
Porkie
Porkie's Avatar
Wicked! thats what I want to hear!
How did affect the traction and handling of the Westy?
Old 03-06-2009, 03:55 PM
It's Czech Mate
It's Czech Mate's Avatar
ATB will be ace on track, grabby on bumpy surfaces tho, where both wheels arent in contact with the floor
Old 03-06-2009, 04:01 PM
JohnnyB
JohnnyB's Avatar
if your car lifts a back wheel then no good.
else brilliant
Old 03-06-2009, 06:21 PM
markk
markk's Avatar
the atb's i have used are ok as long as you never have a wheel eithe rlighter than the other or in the air, as as soon as the wheel lifts that diff will send all your hp to the wheel with the least amount of grip.
there are many differant types ae plated with differing ramp angles to suit your needs pal.
ok ive only used the atb in rally cars but it has been on smooth tar.
Old 03-06-2009, 06:39 PM
cpaul4
cpaul4's Avatar
I use a plated diff on my Celica st205 gt4, seems fine when pushing and have had no troubles of it trying to push you through the corners. Car is 4x4 though so this could be the difference over rear wheel set ups. Any way you can drive both to see which one you prefer? If your near High Wycombe you can take mine for a buzz.
Chris
Old 03-06-2009, 06:46 PM
andrewg
andrewg's Avatar
plated all the way for me for track car!! atb and viscous are unpredictable when the back end steps out,, plated are far more controlable and fun!!
Old 03-06-2009, 06:47 PM
andrewg
andrewg's Avatar
and we have a gripper plated thats been abused for ten years and still going strong
Old 03-06-2009, 06:57 PM
Mike1
Mike1's Avatar
No one seems to go with the re-rated viscous ones for bigger power road cars?
It seems even a standard one needs re-juvenating every so many years - does it make a big difference to anyone that has had it done?
Anyone tried the CTS/Bara re-rated viscous ones?
Old 03-06-2009, 09:45 PM
Touring Car Spares
Touring Car Spares's Avatar
yes, ive used and placed a number of uprated viscous units , they work quite well but nothing like a well sorted plated diff . viscous units deteriorate with heat, you get good grip until the diffs hot and then its hit and miss what it does !! The combination diffs used in the super tourers had both a plated and a Viscous element , totally adjustable - some even externally of the box ! Plated all the way for me , thats my experience and choice , my 500 has an X-trac unit ,very controllable .
Old 03-06-2009, 09:52 PM
J1mbo
B1mbo
J1mbo's Avatar
as andrew said plated are very good, the ramp andgles can be set so that whilst off power and turning the wheels are free, as soon as you go back on the power they lock, instant go !
very good for rally, track aswell but theyre snatchy (apparently ive not driven one)
the ones in the escos are viscous, seems quick enough if yo ask me
also, one thing ive felt with the atb's, when you lift they tend to jump the car across the road, makes the car feel nervous, this happened in 3 cars i went in with them but others think theyre very good ?!
personal opinion, find what works for you
Old 03-06-2009, 09:54 PM
Mike1
Mike1's Avatar
Will that be a issue on a fast road car though? I wonder what Ford's reasons were for using the VC originally on the road car, just the inate friendliness in normal driving or the lack of maintenance required?
Old 03-06-2009, 09:55 PM
wide ka
wide ka's Avatar
ive got a plated tran x diff in my 7 type car, not really pushed it so far tbh, but i know there are setup to what you want ie ramp angle and preload, so can be tailerored to suit your needs
Old 03-06-2009, 10:06 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
imo id get a plated diff.
as for them pushing on in corners, after driving our drift shitter ont he road for a year, with a welded rear diff,, i never found that it pushed on, on tarmac. on gravel etc it would of course as the front end grip was less.
tony, didnt the old RS500 touring cars use spool diffs? ie a solid rear axle essentially?
dont know why, im just not a big fan of the ATBs
but they are cheaper, so may end up with one if i kill mine in the 3dr... when it runs
Old 03-06-2009, 10:49 PM
JonnyBravo
JonnyBravo's Avatar
IIRC the spool diff you mentioned was used in RS500's from the Australian Touring car, I know of someone locally that uses one in his race car and I'm sure I was told they came from somewhere like that the casing was massive iirc
Possibly WAY ott for a Westy though !
Plate diff for me simply as the ATB has the issues already mentioned which I did find noticable and annoying on my own car.
Old 03-06-2009, 11:13 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
just get a welder in there lol
my spare diff will probably go that way
Old 03-06-2009, 11:16 PM
LINCOLN
LINCOLN's Avatar
Just found this if you are running sierra diff. It is an Eaton Posi diff install into standard case.
http://www.mc2racing.com/tech/20081104a/index.html
Think he said something like $700US
Old 04-06-2009, 07:56 AM
Porkie
Porkie's Avatar
No they aren't! I can get a new Gripper cheaper than an ATB.
Don't forget you also need the Quaife output flanges... not just the ATB.
I was all set on a gripper.... but Sean kinda talked me out of it! and I do REALLY value his opinion. His race Exige is the car most similar to the Westy as well I suppose.
I've never been a fan of ATB's... I put one in front of Sierra and then took it out... where as I was always happy with the plated ZF I put in the rear.
Not sure what to do again now
Old 04-06-2009, 07:57 AM
Porkie
Porkie's Avatar
Thanks. I run a 7' though
Old 04-06-2009, 07:58 AM
Porkie
Porkie's Avatar
Yes. Cost as well I imagine.
Old 04-06-2009, 08:14 AM
Spiky
Spiky's Avatar
the 205 guys said i should have gone for a plated diff, but i bought an ATB and they say the plated is more aggresive,
but then, i drive the wrong wheels so my opionion dont count
i like my ATB and wont be changing it
Old 04-06-2009, 08:20 AM
Mike1
Mike1's Avatar
Doesn't CossieRich run a Bara VC diff in his? Does that cope well with his power? ( I don't know how he finds it? )
Could something similar be done to a 7" diff
Old 04-06-2009, 08:21 AM
Porkie
Porkie's Avatar
Thanks Spiky
as you said though... you are WWD mate.
Just called Rainbum... he says its subjective but he would go for ATB.
lets face it though. Tony and AndyG can PROPERLY pedal and are successful racers and thats making me think HARD!!!
have you two guys ever used an ATB on circuit?
Markk thanks for opinion mate. If I was going Rallying... it would definately be a plated, because of the wheel in air problem.
Old 04-06-2009, 08:26 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
That IS the trouble with handling, it is TOTALLY subjective. I loved the ATB in my Sapphire, it was completely controllable and never unpredictable. Could leave black lines anywhere.
You need to drive one with plated and one with ATB to see what you think - or just buy both and do a back to back test, and then sell the one YOU don't get on with?
Old 04-06-2009, 08:32 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
My experience of ATB's is that they are fine at moderate power levels but if you start getting to the point where both wheels are scrabbling for grip in a straight line they can be a little snatchy and pull you about a bit.
For your application I would have thought it would be fine but sadly the only way you will ever know, is to try both types and see what you prefer, as like Mike says, handling is a very subjective area.
Old 04-06-2009, 08:40 AM
Porkie
Porkie's Avatar
Stu is going to HATE that suggestion
Old 04-06-2009, 08:42 AM
Chip
Chip's Avatar
He wont if when you try both you like one and he prefers the other one, cause he'll just end up with the one he wants for free
Old 04-06-2009, 08:48 AM
Porkie
Porkie's Avatar
hmmmm good point hahhahah
anyone got a spare 7' casing?
Old 04-06-2009, 08:52 AM
andrewg
andrewg's Avatar
with atb it can still spin an inside wheel so if you are side on at high speed and the inside wheel lifts a bit it will spin up and the outside one will gain traction again causing it to snatch and prob see you off to the tyre wall.!!
this is only from my experience!!
i use 9" viscous in my focus but i try to drive on the limit of sliding and if it steps out it can be a hand full!
for the road/track i wouldn't have a 4wd or 2wd cos without a plated lsd...
Old 04-06-2009, 09:05 AM
Porkie
Porkie's Avatar
Chris
thanks for offer. 4x4 very different though. gave already used plated in my old sierra at the back.
Old 04-06-2009, 09:11 AM
cpaul4
cpaul4's Avatar
No worries any time, these things can either make or ruin a car for you to drive so need some thought. Best of luck
Chris
Old 04-06-2009, 09:12 AM
Mike1
Mike1's Avatar
Is there no plated LSD available for your set-up or do you stick with the viscous one for other reasons?
Old 04-06-2009, 09:16 AM
saphycozzie-adz
saphycozzie-adz's Avatar
I have an Atb in my rwd saff with 500bhp, its not broken yet and it does get plenty of stick but my beast only roams on the roads. Best diff Ive had fitted along with my Ahmed beam. Sorted.
Old 04-06-2009, 09:19 AM
andrewg
andrewg's Avatar
yes i have a plated also for when i'm not racing and as a back up. i feel viscous has a higher limit of breaking traction when cornering on power, but not always easy controled when it does breakaway!
Old 04-06-2009, 09:22 AM
Porkie
Porkie's Avatar
Now I can add fear into the equation!!!
Old 04-06-2009, 09:47 AM
Mike1
Mike1's Avatar
Found this info from Marco on the smaller VC diffs
Hi Neil
Bara uprates the 7" VC to 180Nm on the standard VC plates
however there are Nickle VC plates available for the 7" which will increase the Viscosity to 240Nm which is nearly 10 times more preload than standard ,the prices of the Nickle plates are more expensive tho
the 7.5" VC can be uprated to 240Nm on standard plates and 400Nm on the Nickle plates due to the actual size of the 7.5 diff it's alot bigger than the 7" unit
as for the planet gears they are uprated items that he makes himself and me being 100% honest i couldn't tell you how much torque they can handle he has fitted quite a few to rally cars and seem to last ok but i think the rally car use alot less power than your car but some of the rally cars will have more low down torque than you
Bara told me a few times now, if people are going to launch their cars time and time again then they might be better of with a plated diff or an atb something that will do away with the planet gears
you cant get a better more road freindly diff than a VC item in simple terms
cheers Marco
Old 04-06-2009, 11:08 AM
Porkie
Porkie's Avatar
Well, just bought an ATB. Thanks to everyone for their advice...
I know Tony, Markk and Andy (all driving gods) said plated....
but Mike and Sean (who said ATB) will actually be driving it alot probably, and I am TOOO clueless to really tell the difference I reckon. So bought the ATB!
Quick Reply: Rear diffs.... info and opinions pls!
