any bmw experts on here?
Compensation Specialist
my 330d has problems
1) it starts every morning fine but if i stop it for some reason when i leave it 10 mins it wont restart i have to wait 45mins then it will start up again, but from cold it starts every time. there is no leaks or holes in pipes.
2) my blowers have stop working my control panel is working but its not blowing any air ie wont go up or down etc and in this weather its bloody hot![Wall](https://passionford.com/forum/images/smilies/wall.gif)
Blower will be the heater resistor they are about £80 quid also known as the hedgehog very common.
2nd fault is most likley the pre supply pump on the floor also very common or a injector either way you will need to get a diagnostic test for this if the fault comes up for fuel pressure regulator or low fuel pressure its defo the pre supply pump
The cam sensor would bring a eml light on most times the lift pump dosent.
A way to check if its a injector is clamp the end of the spill pipe hose & take the hoses off if it trickles out the top the injector is ok if it poures out really bad that injector is fucked.
I did say most times but the light will almost certanly come on with a cam,crank sensor if the fault is not currently present the light will go out but in the diagnostic print out it will say it has occured so many times but fault currently not present..
I work for a bmw dealership with upwards 45 cars in per day so see a fair few.
also it does on full load in high gears hesitate in power like get a flat spot for 2 seconds the ok for few seconds and does it again could this be linked to the starting problem
Yes mate although i stand by my statment if its hesitating when your driving & it was the crank sensor the light eml light would come on. Knowing how bad these cars are i would get someone to check the ppre supply pump if it turns out to be that replace the fuel filter as well. dont be fooled by how mych fuel comes out the pump there was a x5 inn andy gallachers that was pumping fuel out & looked mint but wouldnt rev much past 2.5k turned out to be the pump. They are that bad for going we have one in the workshop that we try first before fitting one because the fault codes dont always lead you to the pump
Defo not the crank sensor then as that will always log a fault even if its not present.
yeah thats correct the early cars have the fuel filter in the engine bay my bet would be the pre supply pump think they are about £250-£300 out a dealership not sure about a factors tho im sure euro car parts will do it alot cheaper
thanks mate ill do the hedghog tommorrow.
ill change the filter also
just a bit worried about taking it to bmw as there a bloody rippoff here and i dont know any other workshops who are good on bmws my bmw just hit 200,000 now lol still drives like new
200k thats good going mate
yeah i know my work is £96 per hour plus vat.
let me know how you get on even pm me after changing the filter & when your in buying the filter & the hedgehog (didnt know the factors did them) would save you a bit of doh if they do. I would enquire about the pre supply pump when your in there just incase
http://cgi.ebay.co.uk/NEW-DIESEL-FUE...3A1%7C294%3A50
pretty sure this is the fella im off sick the now so cant cross reference the part numbers for you
this is from a 330 i was doing tonight
![](http://i483.photobucket.com/albums/rr197/andrewfgallacher/01062009528.jpg)
butterfly broke and went throu the engine bent a valve and slightly marked the bore but thought it would be ok ,, put the head back on and it was breathing like mad!!
so thought must be that mark on the bore, took the engine out got it lined etc back together and found the because it had been exhausting throu the bent inlet valve it burnt a hole in the rocker cover so it would of been getting boost presure rocker area!!
DavidK
27-09-2015 02:55 PM
