How easy is it to remove an aftermarket filler cap?
I'll post a close up picture later. But how easy/hard will it be to change the filler cap back to standard? I've no idea how it's fixed on, are they normally put on using adhesive strips or something?
Any help appreciated.
CheeRS
CheeRS
most of them are adhesive strips like you say so a hairdryer and some Autogym tar remover with the blue label will do the trick.
heat it up and try to peel it off and if theres any sticky stuff left then use the tar remover rub some on leave it 10 - 20 and rub again and it will come straight off
Cheers JB
Cheers JB
I'll give it a go.
Must remember to get a new filler cap first though.
How does the lock work? Will it drop out and go in the original filler cap? Or will I need a new lock as well?
good question bet when you buy a new filler cap you can get one with a key normally after market ones come with there own key well mine did on my 106 but then you can get one that stick on everything the cap and around it to but i dont know what a S1 cap looks like carnt remember.
It's a Dimma cap so just sticks over the original. You won't need to replace the cap itsel unless that one is knackered.
Hairdryer to warm the glue up and it should peel off. Then just clean the residue up with some AutoGlym and your in business.
Was going to sort it tomorrow, but I'm feeling pretty down about the S1 now!
Thanks anyway.
most S1 keys will open any escort mk3 filler car if do need another about Ł1 from breakers S2 ones look the same but have a hexagon type lock and S1 keys dont open them
quote]
I had a look (in the dark!) and it seems that it's exactly how you said.
Thanks anyway.[/quote]
Why whats wrong the s1 then???
Originally Posted by b19bal
if its a proper aerostyle one might be a bitch
S1 For Sale Soon!!!!
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
Fudgey
17-09-2015 01:06 PM
