mini bore out to a 1480 or change the block for a metro turo
Old 27-05-2009, 10:34 AM
cooperad
trevs cossie what a tool
cooperad's Avatar
Default mini bore out to a 1480 or change the block for a metro turo
help
Old 27-05-2009, 11:14 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
You cant bore a mini block to 1480cc anyway realistically.
Do you mean 1380cc? (which is 73.5mm pistons)
Stroked 1380cc using an offset ground modern crank with cooper S rods will give 1430cc
If so, just boring and stroking it wont give you anymore power really, maybe a few bhp but no more than that, it will just drag the torque down the RPM range a bit, you will need a lot of headwork and a decent cam as a starting point for more power on an A Series, the standard head is shocking and the standard cam in a non MG model is poor too.
Turbo is the cheap way to get power, but you'll probably kill lots of gearboxes.
If you want a nippy car, a 90bhp A series works well, if you want a FAST car, ie 150bhp+ then throw the a series in the bin and fit a honda or vauxhall engine!
Old 27-05-2009, 11:23 AM
cooperad
cooperad's Avatar
thank you will do my best
Old 27-05-2009, 01:58 PM
Received 1,044 Likes on 998 Posts
You comic.
Old 27-05-2009, 02:21 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Get up to date Chip surely progess has been made, had more than 100bhp in 1965 with a Supercharger.
Old 27-05-2009, 03:11 PM
Jasesapphy
Jasesapphy's Avatar
Gearboxes wont take over around 100bhp thats more the issue.
Old 27-05-2009, 03:59 PM
Chip
Chip's Avatar
The parts havent got any stronger since then mate.
Exactly, 90bhp is cheap to get, and tends to be reliable, once you venture beyond that, if you drive it hard, you'll be forever spending money.
My trackday 'A' was over 100bhp, but I wouldnt have a big miles 'A' powered road car at the same level personally.
Old 27-05-2009, 04:01 PM
alistairolsen
alistairolsen's Avatar
A series tuning guide:
Step 1: Remove A- series engine....
Old 27-05-2009, 04:09 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Yeh!! guess your right, didnt Jack Knight or some such name make an uprated box its 44 years ago for me & my memory is fadeing like the rest of me .
Old 27-05-2009, 04:10 PM
Chip
Chip's Avatar
Yeah, they've done a few, including a 5 speed, trouble is all the ones which are significantly stronger than standard are straight cut, and straight cut gears in a gearbox which is sharing its oil (and hence swarf) with the engine isnt a great plan for long term reliaiblity.
Old 27-05-2009, 04:14 PM
Benni
Ban[B][/B]ned
Benni's Avatar
What happened to that Mini of yours, Chip? I remember it when I was new here.
Benni.
Old 27-05-2009, 04:30 PM
Chip
Chip's Avatar
I think I probably had 4 when you joined which were:
998cc runabout
1380cc Cabrio
1380cc Trackday car
Vauxhall mini project
Ive still got the runabout and the vauxhall one, but they have both been in storage for years, should be cracking back on with the vauxhall one this winter hopefully if my new unit is built by then
Old 27-05-2009, 04:41 PM
89xr2
Brap!
89xr2's Avatar
What happened to your grand plans for a 500bhp (iirc) front wheel drive yb engined mini Chip?
Old 04-08-2010, 08:09 AM
MM2265
MM2265's Avatar
Smile
Ok, so this is n old post...... however anyone searching for this information really needs to know the facts........
Firstly a 1275 Mini engine can be bored to 1425 with a standard stroke using 74.7mm pistons from the triumph engine range.
Secondly although a 1275 Mini engine cannot be overbored to 1480 they can be "stroked" to 1596cc .... 74.7mm pistons with a Farndon or similar 91mm crank.
Turbo Mini engines are now able to put out in excess of 200BHP
Gearboxes for Classic Mini can be modified to accept 200BHP with pretty good reliability, ie 10,000 miles is reasonable mileage.
Fitting Honda or Vauxhall engines in to Mini's often result in less acceleration as 1st gear is far too low, the gear ratio's are more suited to a full race engine but on the road
In 1968 the British Vita Min (yes it was a pun) run a 1293 turbo with 180BHP, in the mid 80's the turbo challenge ran 240bhp as a norm, since then better machining practices on better materials have resulted in some astounding leaps forward, 16v turbo 1380 .... reputedly putting out 275BHP
My own six speed Aseries dog box has bearings and shafts that can take more than twice the old unit......
it's back to weight transfer now as some of the quicker Mini's are getting in the 11 sec's 1/4 mile at over 125mph.
Old 04-08-2010, 06:17 PM
Stud nicklaus had some serious power, boxes to take over 100bhp all day long have been avaialable for years, built to order, if he's still going, by Graham Boulton, of E Dereham, Norfolk, who did a lot of the original boxes on the proper italian job film.
Lotus when developing the turbo metro were killing boxes with std mg power, ie 72, beleive it's the centre web rips out ?
Old 04-08-2010, 06:20 PM
Chip
Chip's Avatar
Was a vauxhall engine not a YB mate, and I decided it was to much so its what I put in the nova in my sig.
Still got the mini, but not sure what I'll do with it, either vauxhall engine but more moderate power or celica gt4 power possibly.
Old 04-08-2010, 06:29 PM
clairendave
Dave not Claire.
clairendave's Avatar
Completely agree Chip. I own an ex race Mini from MBE in Lincoln. it is road legal and over 80 Whp from a 1293. it is horrible on the on the road as it is so highly tuned. (and bloody thirsty)
yes all the parts are available to retain reliablity these days, but you pay for them, go look on www.turbominis.co.uk its definatly the way forward for a fast road car thats reasonable to drive 'most' days.
Old 04-08-2010, 06:58 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by mra-minis.co.uk
In 1968 the British Vita Min (yes it was a pun) run a 1293 turbo with 180BHP.
Not 100% true if i remember correctly.
It was Supercharged, Fuel injected & 8port, not a Turbo & the 180 was never proved. Was fast in 1968 but its 2010 now .
Old 04-08-2010, 07:59 PM
MM2265
MM2265's Avatar
If it was supercharged ..... then maybe there was 2 of them as the photo I have is definately a turbo
And yes mechanical fuel injection.....
Old 04-08-2010, 08:43 PM
stevieturbo
C**t
stevieturbo's Avatar
100bhp is nothing, and could easily be ultra reliable.
Even 150bhp can be achieved without any trouble and a good straight cut will handle it all day long.
The metro turbo used lower boost in the mid range to try and save the gearboxes. But basically the std gearset was soft as anything, and were very easily stripped.
Although centre webs do crack too eventually if you get silly.
Old 04-08-2010, 09:18 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
British Vita were one of the most successful A series tuning houses of the 60's. They were consistently innovative in their thinking and were responsible for "among other things" the first semi space framed Mini, the first 3.5 litre rear wheel drive Mini and the very first "weight saving" glassfibre flip up front end. Although the y competed very successfully throughout the 60's in a whole range of motor sport both as "Works" Supported" entrants or in the later years as a full blown works team their finest season was that of 1968, the statistics were as follows.
John Handley
1968 European Touring Car Champion. Division One. BLMC 999cc Mini Cooper 'S'. Also highest overall points in European Championship (48).
Car Prepared by: B.V.R.T. Ltd.
Harry Ratcliffe
1968 B.R.S.C.C. Northern Saloon Car Champion. BLMC 999cc Mini Cooper 'S'.
Jeff Goodliff
1968 B.A.R.C. Hill Climb Champion. BLMC 1293cc Supercharged Mini Cooper 'S'.
The famous 180bhp car had Sprint (cutdown) bodywork.
Anything else you have seen is not an orginal car from 1968. I was supercharging Minis at the time .
Old 04-08-2010, 11:48 PM
Ginge
www.virtualseason.net
Ginge's Avatar
Love mini's!
Ginge
Old 02-02-2014, 06:01 PM
mini hot rod 99
mini hot rod 99's Avatar
hi all new boy i raced a 1480 mini as a hot rod on grass and tarmac you need a 1300 block bored 76.5 using triumph 2.5 piston a standard 1330 crack off set ground 84.4 a 39 31 valve head straight cut drop gears a jack knight box with lsd a 48 single webber cars will give you 121 aprox bhp at the wheels aprox 151 bhp at the flywheel faster than most 177 2lt pinto fords and that was 25 years ago now cheaper to fit a 2lts vauxhall red top hope that helps
Old 02-02-2014, 06:02 PM
mini hot rod 99
sorry 1300 crank
Old 21-02-2014, 10:31 PM
MM2265
MM2265's Avatar
Oh please I wish you armchair types would do your home work.....
1480cc Mini engine is a combination of 74mm bore x 86mm stroke, any maths types can easily prove this !
The crank is NOT a standard item, it has to be a bespoke crank or made from a brand new forging (rare to say the least).
The pistons are NOT triumph but well respected OMEGA's or similar, can be Simca if you can get them.
1635cc is the biggest possible A series that I have built !!! yes built not talked about people.
This is 74.7 (triumph pistons) by 93mm stroke, not overly reliable but s*** loads of torque.
anything over 84mm stroke will need an older A series block
and to stroke a standard crank you will again need an A series as the A+ has rolled fillets and is not any use for offset grinding
Old 21-02-2014, 10:41 PM
MM2265
MM2265's Avatar
If they are driven by a moron I agree, however thats true for almost any car on the planet !
I have seen over 200bhp reliably from an A series without destroying the box, half the battle is uprating the correct parts and building it correctly.
My own is 180 bhp turbo with over 84k miles on the same gearbox, numerous clutches but thats another story
Old 21-02-2014, 10:48 PM
Rax
Rax's Avatar
Mega thread revival but while youre at it.My old mans cousin still has a 998 cooper in his garage chocolate roof.And my old bloke went to Italy and back in a fasterish cooper because they used to race them back in the day.Does this count for this thread .
I will add when MY mates had them when I was younger.I used to menace the fuck out of the "fast" minis in my Fiat 127 sports/Gt's.
I never lost an once of sleep
Old 21-02-2014, 10:49 PM
MM2265
MM2265's Avatar
For those wishing to build a high power Mini us the later 3 bolt case, this is the case with yep you guessed it ! 3 bolts.... holding the double roller bearing in to the case, there are other mods as well that increases strength and reliability.
PS 320bhp from an A series turbo and that is without NOS
Old 21-02-2014, 11:28 PM
Rax
Rax's Avatar
Anyhoo when my sister had a 12 month old MGTutrbo it was shit.My mate had one that was a lot faster and I drove to buy 1 or 5 .Crap !!
320 bhp from that Pfftt.I think as they were only 105bhp stert with.(turbo)
Old 21-02-2014, 11:56 PM
MM2265
MM2265's Avatar
Not too sure what "pfftt" means ? does your keyboard have a stutter ??
When you consider that the A series first went into production as an 803cc unit with a massive 32bhp
Now consider it against the Cosworth 2 litre turbo used in Sierra's that would have to have 2250bhp to get the same % increase
PS the Turbo was 93bhp not 105bhp, not sure where you got that figure from ?
Old 22-02-2014, 05:39 PM
Rax
Rax's Avatar
Ok I was a bit abrupt so I will apologise for that.I am a bit black and white plus I had beer.
No, no stutter I just found it quite hard to believe the power you quoted and tbh I still do.Genuinely interested if you have any links or videos for such said power.
I know there is a guy on here that has a YB powered mini (sarny) maybe.Good build and there is videos.
Any links would be appreciated and I will show my mate down the street seeing as he owns12 of the buggers in different guises he will like.
Old 22-02-2014, 05:44 PM
Does your keyboard have a stutter..... fpmsl at that.
Old 22-02-2014, 06:19 PM
Rax
Rax's Avatar
Get lost Glenn dont you start
Old 23-02-2014, 06:35 PM
MM2265
MM2265's Avatar
[quote=Rax;6430078]Ok I was a bit abrupt so I will apologise for that.I am a bit black and white plus I had beer.
Over 30 years of redesigning and manufacturing parts for Classic Mini has taught me a few things.... one of those things is that, there are a few people who don't believe what they are being told and think that it makes a difference to me if you believe it or not
I have trashed sierra cosworths with reputably 400bhp, in my own turbo mini, I have seen the mess after a "disbeleiver" thought that his Volvo could out brake a seriously modified Mini (285mm front discs with 4 pots) I have even seen the fastest mini in the world ... which still is a Classic Mini, I have been witness to so many people losing face to a Mini that I am pretty sure you wouldn't believe it but do I care ? Not really, I understand that when somebody loses to a Classic Mini they won't tell anyone about, certainly won't bragg about down the pub, so I just enjoy out accelerating M3 BMW's and Ferarri's etc.... but I don't even bother with the boy racer brigade, the people that couldn't believe anything even with the proof disappearing from their forward view
However for those that are truly interested in amazing machinery....
http://www.minitorque.com/forum/f212...s-turbo-27088/
Old 23-02-2014, 06:43 PM
MM2265
MM2265's Avatar
Hears a video, however I haven't got sound so don't know if this is an old vid or not..
http://www.streetfire.net/video/mini-turbo_44197.htm
Old 23-02-2014, 06:56 PM
Rax
Rax's Avatar
Righto a bit of trumpet blowing but if this is you and your car I believe you "not that it makes a difference to you,or me neither for that matter.I only asked for a link .
Beat me to it then.
Old 23-02-2014, 07:05 PM
markk
markk's Avatar
If you polish a turd all you have is shiny shit, minis have to be the worst car I have ever owned or modified or driven.
I would never own one again ever. They couldn't handle the standard power never mind ploughing loads of money into one to make it handle even worse (if that is possible).
Each to their own I suppose.
Old 23-02-2014, 07:09 PM
MM2265
MM2265's Avatar
No its not my car, mine will do as I said on 180bhp
There is an acceleration chart for Matts Mini ... 80 to 116 in just a tad over 4 seconds, most Minis with 200bhp will clear 0 to 60 in sub 3.5 seconds, my own does it in 1st gear
Mph in gears
1 = 62
2 = 88
3 = 112
4 = 138
5 = 160
6 = 179
Yep its a 6 speed in an A series
Old 23-02-2014, 07:16 PM
MM2265
MM2265's Avatar
so why would you want to do that !!!
that is simply stupid and a remark I'd expect from somebody who knows bugger all about cars !
If you buy a shit escort you will get the same results chap
If you know anything about cars you will also know that it doesn't matter what car it is, who made it or even what colour it is..... with the right work and amount of expense you will get a good car... this even works on Escorts
Old 23-02-2014, 07:21 PM
MM2265
MM2265's Avatar
I do have a Transit as well.... just in case you thought I only had a Mini
6 speed 140bhp crap at towing though kills clutches like they are going out of business :-(
I have manufactured parts for Fords, as OEM and aftermarket, standard and performance, if you own a sierra then you will have parts that I have made on your car
Quick Reply: mini bore out to a 1480 or change the block for a metro turo
