Help!!!! Xr2i superchip problems!!!
Old May 17, 2009 | 07:56 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
Default Help!!!! Xr2i superchip problems!!!
Hello every1,
Basically i own a J reg Xr2i 1.6 8v with a few mods, i bought a genuine"superchips" chip (not 1 of them shitty resister jobs) from ebay, but when i fitted it my car started misfiring and spluttering and all sorts of madness, i tried reseting the ECU by pulling the + lead of the battery and adjustin the fuel pressure up to 2.5 bar but all to no avail, the car smells like its burning a shit load of fuel and hesitates alll through the rev range, i also noticed that when i turn the ignition on the fuel pump does not do a pre-run it just runs as if the car is started, quite strange i think, when i contacted the seller he assured me he had only just unplugged it from the car the morning he posted it and it was all working fine, im baffled to be honest.
If some1 could help id be veryy gratefull.
Old May 17, 2009 | 08:12 PM
Icurus's Avatar
Icurus
Is the code on the chip a match for your ecu?
On my mk5 RS2000 I have a 1AGB ECU and the Superchip has to have a matching map flashed onto it.
If yours is ok, then it could be that the contacts need cleaning as they are usually coated with a thickish waxy substance. Carefully scrape and clean this off with the ECU removed from the car.
Does the car run ok with the Superchip removed?
Old May 17, 2009 | 08:14 PM
Jim Galbally's Avatar
Jim Galbally
im confident that you have fitted the WRONG chip to your car.
it is also possible that this has damaged the chip and/or the ECU
remove it immediately and contact the supplier reporting the problem.
then go and buy from a REPUTABLE dealer like www.motorsport-developments.co.uk
iirc the fuel pump not priming as normal is a sign the the ecu has entered Limited Operation Strategy (LOS) aka limp home mode
Old May 17, 2009 | 08:15 PM
costina's Avatar
costina
Live long and prosper!!
You need a fibreglass pencil for cleaning the contacts (maplin) Ł5.99 also its easier to do this by taking the ecu apart just remember to clean both sides
Paul
Old May 17, 2009 | 08:39 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
xr2is have various codes, gotta get teh right code for teh ecu, putting an ofac chip in an ofab car will do tthe same
8v xr2i;s are usally 1afa or early are 999a 16v;s cant be alsorts, a list on escevo i think of all ford ecu codes
Old May 17, 2009 | 08:40 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
Ye the cars runs just normall without the chip plugged in, ive seen something about the ecu contact being worn, looks like the cintacts on the chip has been sprayed with white grease aswell i no that probably dont help with contacts,
Ive been tryin 2 find out about the code on the chip to match the ecu but i cant find any sort of reference anywhere,
these are what the chip has on it
LAFA PWR
1146
Old May 17, 2009 | 09:03 PM
Icurus's Avatar
Icurus
Do you still have the ebay link to your purchase?
Old May 17, 2009 | 09:04 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
anymore ideas would be a great help just tried my other ecu with mint contacts and cleaned off the white grease still the same............doin ma head in now, contacted seller too he said he'l give me my money back but 2bh i really wanted this chip and they are gettin kinda rare now 2 get 1 second hand, and f**k buyin a new 1, Ł299 for 10bhp MAX power gain....
any helps better than no help
Old May 17, 2009 | 09:05 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
yes but the auction is closed now.
why?
Old May 17, 2009 | 09:15 PM
Icurus's Avatar
Icurus
To see if he gave any info about whats on the chip.
Old May 17, 2009 | 09:52 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
no it was probably ebays smallest ad lol, just said xr2i 1.6 8v superchips chip, only removed due to selling car and taking best bits off.
happy bidding.
Old May 18, 2009 | 07:04 PM
Jim Galbally
please read what i have written as it is CORRECT. stop plugging the thing in!
chips need to match ECUs!
the white grease should always be removed prior to fitting, obviously your chip was NOT froma reputable supplier if he didnt provide you with these simple instructions, nor even find out what ecu you had
Old May 18, 2009 | 07:17 PM
Rob M666SCC's Avatar
Rob M666SCC
Def sounds like a connection problem or incorrect file on the module to me.....
For your info the Current Superchips price is Ł234 all inc !!
Old May 18, 2009 | 07:27 PM
Toe Knee's Avatar
Toe Knee
find out what codes his ECU has on it and see if it matches yours, also what spec the engine was ie was it a chip for an uprated cam etc, althou tbh it should still run fine off cam, im assuming your engine is standard?!
Old May 18, 2009 | 07:36 PM
1.9 xr2 on 40's
st170 breaking
just get another chip with the right code or dont bother with one
they usually go about for less than 50 quid
sell yours like he did or as 'ready to be reflashed'
Old May 18, 2009 | 08:07 PM
Jim Galbally
i doubt yoll get one for <50quid even from the ebay copiers. the modules themselves cost more than that before programming. its not like cossies where the eprom is worth 10p
Old May 18, 2009 | 08:10 PM
Rob M666SCC
You may even be able to program this module with the correct file.....
Old May 18, 2009 | 08:27 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Do yourself a favour and remove it, without reading the rest of the thread...its unlikely its giving any beneficial gain in power anyway!
Old May 18, 2009 | 08:32 PM
1.9 xr2 on 40's
st170 breaking
i used to buy and sell dozens of em, buy em for as little as Ł5 but with a decent listing and knowing what its actually for i would sell em for Ł50 n/a more if poss obviously frst and the like would do more like Ł100
put a wtd on ft and a few will pop up, theres a zetec 1 on escevo for a nifty atm
Old May 20, 2009 | 10:17 AM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
i have unplugged it now, cba with it anymore, sending it back 2moro aswell gettin my nifty back aswell, so lesson learned, dont buy electricals from ebay,
Whilst we are on the subject a mate of mine bought 1 of them resister things for his puma only Ł6.99 advertised as a chip lol, i was adament it would never work but still reluctantly i fitted it to his air flow meter, IT ONLY FECKIN WORKED.
i couldnt believe it we noticed the difference straight away it was a shit load more responsive and seemed 2 pull a bit better and eliminated the flatspot between 2500 and 3000, i never thought it was possible just by telling the ecu to overfuel.
any1 else every tried 1 of them?
Old May 20, 2009 | 10:39 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Your mate bought a 20p resistor for Ł6.99
All these do is tell the ECU its freezing cold and it overfuels, it will fuck his cat up and possibly borewash over time...
Chuck it and get it done properly
Old May 20, 2009 | 05:23 PM
Jim Galbally
your mate needs to remove this NOW. he does not understand how it works and he NEEDS to do this!
Old May 24, 2009 | 06:20 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
How will he get bore wash its not like its throwin in way to much fuel so its chuckin out black smoke, all it is doin is tellin the e.c.u to basically keep the choke on, another friend of ours (the reason why he decided to get 1 of these resistor thing) has had 1 on his cougar for well over 2 years and he's never had any problems, if it was overfueling to the extent to cause damage from experience i would expect it to keep killin spark plugs.
If it does blow up just mean some extra cash 4 me 2 fix it 4 him lol =D
Old May 24, 2009 | 06:22 PM
Dru_xr2i's Avatar
Dru_xr2i
0-60......now!!
aswell, it aint got a cat anymore so the cat fuckin up aint a problem,
Old May 24, 2009 | 06:26 PM
Paul_RS's Avatar
Paul_RS
Oh
and
Dear
resistor - bin it
Old May 24, 2009 | 09:05 PM
Jim Galbally
dru
do you fully understand the complex working of electronic fuel injection?
do you fully understand the complex workings of an internal combustion engine?
if the answer to either of the above is "no" then why would you even try to defend the stupid arse comments above
im telling you now for a fact that i KNOW its bad idea. can you tell me what you KNOW it isn't?
Old May 24, 2009 | 09:42 PM
costina's Avatar
costina
Jim don't bother mate
Just remember its cool to waste money on fuel with fook all gains
You have tried hardbut some don't listen to wise words
Anyway i'm off to put that duff cts sensor back in mine to give it more fuel
Paul
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Andypandy260
Sep 23, 2015 10:28 PM
